Need help on Automatic rescale failure
Need help on Automatic rescale failure [message #70060] Tue, 18 June 2013 19:44 UTC Go to next message
avatar adamb86  is currently offline adamb86
Automatic rescale failed. Model is not within acceptable bounds in mm (0.00002 x 0 x 0), inch (0.0006 x 0 x 0), or meter (0.02358 x 0 x 0).
The above is the automated response that I received. I'm trying to get this brick wall to print laying on its back rather than standing up. It uploads no problem while standing. I feel that it will print better on its back. I have another one that I was messing around with and that was positioned on its back automatically or maybe I changed the dimensions accidentally. Hopefully someone can help me solve this issue.
  • Attachment: Untitled2.dae
    (Size: 1.86MB, Downloaded 58 time(s))
[Updated on: Tue, 18 June 2013 19:49 UTC]
Re: Need help on Automatic rescale failure [message #70066 is a reply to message #70060 ] Tue, 18 June 2013 21:53 UTC Go to previous messageGo to next message
avatar JACANT is currently online JACANT
Upload the stl file as millimetres. There are a few thin walls in your model. see image. It may be rejected.
Although the wall is now laying on it's back. There is no guarantee that Shapeways will print it this way.
index.php?t=getfile&id=34620&private=0
Re: Need help on Automatic rescale failure [message #70067 is a reply to message #70066 ] Tue, 18 June 2013 21:59 UTC Go to previous messageGo to next message
Thank you very much. I appreciate it. It's going to be printed in FUD and I have uploaded them standing with no issues. I have several variations with the same concept and all uploaded. Are you saying that it may get rejected even though they pass the automated approval step?
Re: Need help on Automatic rescale failure [message #70068 is a reply to message #70067 ] Tue, 18 June 2013 22:06 UTC Go to previous messageGo to next message
That's correct.
The first automatic check is basically to see if the model is watertight, no check is made on the wall thickness untill it goes to production.
You may be lucky using FUD read this http://www.shapeways.com/materials/frosted-detail-design-gui delines on wall thickness.
Re: Need help on Automatic rescale failure [message #70069 is a reply to message #70068 ] Tue, 18 June 2013 22:12 UTC Go to previous messageGo to next message
I believe that I stayed above the minimum wall thickness. I hope it works out.
I have one more question, say I put a hole in one of these walls and want create an object insert it separately, what is the minimum clearance you would use? Both printings will be in FUD.
Thank you.
Re: Need help on Automatic rescale failure [message #70070 is a reply to message #70069 ] Tue, 18 June 2013 22:19 UTC Go to previous message
This may answer your question. http://www.shapeways.com/tutorials/designing_mechanical_part s_for_3d_printing
It will also explain the orientation of models not being guaranteed.
There is more info here http://www.shapeways.com/tutorials/?li=nav
Previous Topic:STAR TREK
Next Topic:Mystery sphere
