The Sphere Cup
The Sphere Cup [message #69926] Sun, 16 June 2013 20:42 UTC Go to next message
Shapeways Crew
I had not designed a coffee cup for a long time. The previous one was the Moebius Cup I think.
So here is a new one.
The Sphere Cup:
http://images.shapeways.com/model/picture/674x501_1158390_1076362_1371403075.jpg
http://images.shapeways.com/model/picture/674x501_1158390_1076365_1371403086.jpg
This cup should contain 50ml of coffee, enough for an espresso.
Its design is very simple: it is only made of spheres and planes. the advantage of the sphere is that it contains a maximum of volume for a minimum of surface.
I used a new technique of modeling to insure a constant thickness and no sharp angle.
I hope you will like it. Any feedback is welcomed.
[Updated on: Sun, 16 June 2013 20:45 UTC]
Re: The Sphere Cup [message #69927 is a reply to message #69926 ] Sun, 16 June 2013 20:49 UTC Go to previous messageGo to next message
Not sure if this is the feedback you wanted, but "the model is private" Smile
Re: The Sphere Cup [message #69928 is a reply to message #69927 ] Sun, 16 June 2013 21:42 UTC Go to previous messageGo to next message
Shapeways Crew
Laughing
Sorry about that (kind of beginner's mistake, shame on me!).
Re: The Sphere Cup [message #69929 is a reply to message #69928 ] Sun, 16 June 2013 22:02 UTC Go to previous messageGo to next message
Shapeways Crew
I realize that perhaps it is not easy to understand the shape of the handle: it is a flat portion of disc filling the void left when removing from the initial sphere another sphere of the same size. A second disc makes the bottom of the cup.
I added a picture, upside down, to clarify:
http://images1.sw-cdn.net/model/picture/674x501_1158390_1076846_1371419692.jpg
Re: The Sphere Cup [message #70036 is a reply to message #69929 ] Tue, 18 June 2013 15:35 UTC Go to previous messageGo to next message
Looks good as a conversation piece, but probably not easy to grip and might get uncomfortably hot ?
Re: The Sphere Cup [message #70057 is a reply to message #70036 ] Tue, 18 June 2013 19:24 UTC Go to previous messageGo to next message
Shapeways Crew
Well, I hope you can put your fingers far enough from the hot inner surface, but this is something to check. Regarding the grip, the model is quite small and even with coffee inside, it will e relatively light, so I hope you can grab it!
But, this being said, you are right: I designed this cup more with aesthetical considerations in mind than functional ones Very Happy.
This will be also the case with my next cup that is currently being uploaded....
Stay tuned.
Re: The Sphere Cup [message #70062 is a reply to message #70057 ] Tue, 18 June 2013 21:00 UTC Go to previous messageGo to next message
Shapeways Crew
I took me more time than expected because my first version was too big (100ml) and thus too expensive: like the Sphere Cup, this new version should contain 50ml of espresso.
Here is the Not So Concave Cup.
http://images1.sw-cdn.net/model/picture/674x501_1162758_1081576_1371587813.jpg
http://images1.sw-cdn.net/model/picture/674x501_1162758_1081580_1371587830.jpg
This is an upgrade of the Concave Mug: its new shape is more efficient in terms of capacity (that's why I made it smaller). But it is not as concave as the initial shape, thus its weird name.
Only the inner sphere should be hot (hopefully Smile).
Re: The Sphere Cup [message #70243 is a reply to message #70062 ] Fri, 21 June 2013 09:16 UTC Go to previous messageGo to next message
Thumbs up!!
Re: The Sphere Cup [message #70251 is a reply to message #70243 ] Fri, 21 June 2013 11:10 UTC Go to previous messageGo to next message
Shapeways Crew
Thanks Bart. I ordered both of them this morning. I will post pictures as soon as I receive them.
Re: The Sphere Cup [message #70314 is a reply to message #70251 ] Sat, 22 June 2013 13:33 UTC Go to previous messageGo to next message
Concave cup rocks Smile
Re: The Sphere Cup [message #70349 is a reply to message #70314 ] Sun, 23 June 2013 19:13 UTC Go to previous messageGo to next message
Shapeways Crew
Thank you mkroeker Smile
Re: The Sphere Cup [message #71474 is a reply to message #70349 ] Thu, 11 July 2013 20:16 UTC Go to previous messageGo to next message
Shapeways Crew
I forgot to mention here that they arrived!
Re: The Sphere Cup [message #71643 is a reply to message #71474 ] Tue, 16 July 2013 06:28 UTC Go to previous message
Shapeways Crew
Concerning the Not So Concave Cup, even if it is not as a suitable cup as I expected, I love the shape so I will keep it. But I decided to rename it. When I showed it someone told me that it looked like an hypercube. And this is true. So I decided to rename it Hypersphere, and I designed its little brother, the Hypercube.
https://images1.sw-cdn.net/model/picture/674x501_1213310_1140167_1373955778.jpg
What those objects are intended for? I let you decide! Personally, I just love them!
But instead, I have good hope that the Half-Hypersphere will be suitable as an espresso cup.
https://images1.sw-cdn.net/model/picture/674x501_1205995_1139213_1373920962.jpg
Previous Topic:Trying to make a Personalize Stamp...
Next Topic:Need Help: Sculpting a Full-face Helmet to Fit
