Hi, thanks for your responses. I'm a novice at 3D printing, but you can see my work online at annpreston-sculptor.com, but anyway, I've begun to work on it a little, Do correct me if I get this wrong.
First of all durability and archival are different properties. Durability is if you wack it, drop it, grind it etc., what will happen. Archival is how long and perfectly will a material last under good conditions. The second is what I'm most concerned with here. For art objects, the problem is that we are using a new material here with no significant track record. So anyone who has been at this awhile, what do you see? For example, are things yellowing, using flexibility, becoming more fragile with age?
All I've done so far is review the basic materials on a simple level , and begun to think about the structure of those materials while being printed. In a couple of weeks I should be able to talk with people and NASA JPL who are using 3D printing for space going parts. They will have done some thorough research.
STRONG and FLEXIBLE and ALUMNIDE are sintered nylon, and sintered nylon with aluminum. Nylon has good toughness, high strength, good flame retardant. On the other hand, it oxidizes, and is susceptible to acids and bases, and absorbs water with a related dimensional instability. In landfills nylon lasts 30 or 40 years. The sintering involves "melting" each particle so that they join with their neighbors, much like wet ice cubes refrozen. This makes the material very porous, which is why they can dye it. The small particle size and exposure to air probably accelerate any degradation over time to an unknown degree. I am wondering if saturating and painting it with acrylic gesso might stabilize it, but suspect that this might shrink and warp structures as they dry. One way to find out.
DETAIL PLASTIC is acrylic. Acrylic is used in archival artist paints so it is very long lasting, possibly centuries. . It has good weather, and chemical resistance, good UV, good toughness. It has good transparency, and is flame resistant and does not bad chemical when burning (good for lamp shades) On the other hand it is susceptible to solvents stress, it is not flexible, and can crack on impact. The 3D printing is not sintered, so it is a solid material. This looks like a good bet for longevity. I note that Golden paints recommends a UV resistant final coat, probably to protect pigments, but not a bad idea.
STAINLESS STEEL, and the bronze it contains are also very long lasting. However, in 3D printing, the metal grains are glued together. I do not what this glue is, or how permanent it is, or if it survives the next step, which is flooding the porous structure created with bronze. I believe that is a question to find out about.
Colored dyes are frequently very fugitive.
Anyway, that's it for now. Thanks for your responses they were quite accurate. Ann
