1.5 inch cube incorrectly shows up as 3.8 inches in Shapeways software
Discussion in 'Software and Applications' started by 376943_deleted, Jun 13, 2013.
  1. Hello! First post.
    Using Autodesk Inventor, I created a small 1.5 inch cube, which I exported as a .CTL and uploaded to this site. The cube was a test intended to verify that this service would work, before actually investing time to make a useful model. The cube showed up fine, except the scale was off. 1.5 inches turned into 3.8. Is this a known/common issue? What can I do to fix this?
    Thank you for your assistance! I'm looking forward to making awesome things.
    wes_ismore
  2. stonysmith
    stonysmith Well-Known Member Moderator
    Upload it as millimeters. See if that fixes it.
    1.5 * 25.4 = 38
    Your software is exporting the model in metric units, even though it may be reporting inches onscreen.
  3. bartv
    bartv Member
    Hey wes_ismore,
    can you share that STL file with us?
  4. This should be it! From autodesk inventor
    • test.stl
      File size:
      684 bytes
      243
  5. bartv
    bartv Member
    Hey wes_ismore,
    stonysmith is almost right: the file is in centimeters. I'm not familiar enough with Inventor, but a simple fix would be to scale it up x10 in Inventor, export to STL and upload in mm.
