Model Complexity
Model Complexity [message #69763] Thu, 13 June 2013 17:35 UTC Go to next message
avatar JeremyMallin  is currently offline JeremyMallin
Does actual polygon count affect printing time for any of the machines? Or are envelope and volume the only important factors? Just curious. I saw a web video somewhere that suggested "model complexity", rather than scale or density alone, was a factor in print time.
Re: Model Complexity [message #69764 is a reply to message #69763 ] Thu, 13 June 2013 17:37 UTC Go to previous messageGo to next message
I'm not sure if polys effect processing time, but the print speed should only be effected by the amount the print head needs to move.
Re: Model Complexity [message #69767 is a reply to message #69764 ] Thu, 13 June 2013 17:59 UTC Go to previous messageGo to next message
Thanks. That's what I was thinking, but that video (don't remember the link, sorry) made me ask. Your explanation sounds much more logical. Thanks. That was a fast reply by the way.
Re: Model Complexity [message #69801 is a reply to message #69767 ] Fri, 14 June 2013 08:40 UTC Go to previous messageGo to next message
avatar Arnaud3D  is currently offline Arnaud3D
Logical ? Not sure. Because you are forgetting the thickness of the printed layer. It is possible to adjust the laser beam power to print thicker of thinner layers. With a low resolution, your layers could be thicker.
I don't know how Shapeways work but there is a big gain in printing time made possible by adjusting layer thickness.
Arnaud
Re: Model Complexity [message #69882 is a reply to message #69763 ] Sat, 15 June 2013 14:32 UTC Go to previous message
JeremyMallin wrote on Thu, 13 June 2013 17:35
Polygon count alone doesn't affect print speed in the machines we use here at Shapeways. In the Strong and Flexible family of materials; a part with greater surface area will take longer to print by a small amount as the laser scans a bit slower around the outside perimeter than is does when sintering the material in the interior. This effect is very small though and affects the print speed much less than added volume. In all of the other materials, the surface area and polygon count are almost irrelevant to print speed.
Previous Topic:Opinions on how this will turn out
Next Topic:How to apply color to a model?
