DB5 Wheel
DB5 Wheel [message #69340] Thu, 06 June 2013 21:34 UTC Go to next message
avatar Mustang  is currently offline Mustang
First I would like to say hello to everyone.
I have no back ground in 3D modelling or now how it works, so sorry for my ignorance.
What I would like to now is this is their someone that can design the items and make them. I can supply pictures of the real item and the sizes of the model wheel I have.
Real wheel.
index.php?t=getfile&id=33882&private=0
Thank you very much for any help.
Re: DB5 Wheel [message #69343 is a reply to message #69340 ] Thu, 06 June 2013 22:00 UTC Go to previous messageGo to next message
I could do it for you, but it depends on the scale you want. Each of those wires would need to be 1mm thick. Minimum wall thickness. So in the real world at say 1:8 scale they would be 8mm - 0.315" thick.
The fins on this rim are 1mm thick. 1:8 scale
http://tinyurl.com/l2zsy5l
Re: DB5 Wheel [message #69345 is a reply to message #69343 ] Thu, 06 June 2013 22:08 UTC Go to previous messageGo to next message
Oops yes scale would help its a 1/8 scale car.
The picture is to show the model wheel that was supplied as they are wrong in that the spokes are incorrect.
index.php?t=getfile&id=33982&private=0
the real spokes are 8mm.
[Updated on: Fri, 07 June 2013 20:33 UTC]
Re: DB5 Wheel [message #69908 is a reply to message #69340 ] Sun, 16 June 2013 07:55 UTC Go to previous message
Thank you to all that have helped. This has now been designed.
Previous Topic:Need help with design AND 3D printing - small ring design
Next Topic:Ring Designer Needed
