Which service is SLA?
Which service is SLA? [message #68696] Sat, 25 May 2013 23:30 UTC Go to next message
avatar SWuser  is currently offline SWuser
I need to print in SLA? What does Shapeways call this?
Re: Which service is SLA? [message #68697 is a reply to message #68696 ] Sun, 26 May 2013 00:17 UTC Go to previous messageGo to next message
If by SLA you mean a pool of resin that is solidified by some kind of light (laser beam or full frame projection), none.
Re: Which service is SLA? [message #68968 is a reply to message #68696 ] Fri, 31 May 2013 12:17 UTC Go to previous messageGo to next message
Why do you need SLA specifically? Our Frosted Detail and Frosted Ultra detail use a photocured resin that is extremely similar to resins used in SLA.
Re: Which service is SLA? [message #68970 is a reply to message #68968 ] Fri, 31 May 2013 12:29 UTC Go to previous messageGo to next message
Well it turns out that I can't use SLA. The parts are for use in continuous sunlight.
Re: Which service is SLA? [message #68975 is a reply to message #68696 ] Fri, 31 May 2013 12:57 UTC Go to previous messageGo to next message
You will have trouble, even with most injection molded plastics, with extended continuous sunlight exposure. I believe Nylon (WSF and Dyed SF) would stand up the best physically over time. Dyed would possibly fade, and both will get dirty if not sealed.
Re: Which service is SLA? [message #68990 is a reply to message #68975 ] Fri, 31 May 2013 15:08 UTC Go to previous messageGo to next message
Our White strong and flexible plastic will yellow over time if put under direct sunlight. Painting does provide relatively good protection from UV though.
Re: Which service is SLA? [message #68996 is a reply to message #68990 ] Fri, 31 May 2013 16:43 UTC Go to previous message
We are currently using PET, and at least for the past year, it's been stable.
Previous Topic:Strong & Flexible plastic
Next Topic:3D printing in color
