molding [message #68371] Mon, 20 May 2013 18:42 UTC Go to next message
avatar omersianto  is currently offline omersianto
I want to print a jewelry model and after i want to send it for rubber or silicon mold.
Do some one know if i can use the Strong & Flexible Plastic so i will be able to send it for molding ? if not can some one recommend which material will be best for it?
Thank you for the help,
Omer.
Re: molding [message #68374 is a reply to message #68371 ] Mon, 20 May 2013 19:03 UTC Go to previous messageGo to next message
You can use WSF, but FUD will give a better definition and surface finish. You will have to use RTV silicon for the mould as both WSF and FUD will have problems with heat vulcanising.
Bill Bedford
Re: molding [message #68389 is a reply to message #68374 ] Mon, 20 May 2013 23:38 UTC Go to previous message
Thank you very much for your quick replay,
I'm new with the materials and i don't know which one you mean when you wrote WSF or FUD.
Thank you again,
Omer.
Previous Topic:premium silver
Next Topic:Reinforcing Thin walls white plastic
