Reverse Rings
Reverse Rings [message #68167] Thu, 16 May 2013 19:00 UTC Go to next message
avatar MichaelMueller  is currently offline MichaelMueller
I've got two new rings. This ones are occupied by a snake and a bird ... can be used as pendants instead. Wink
Michael
index.php?t=getfile&id=32549&private=0
index.php?t=getfile&id=32548&private=0
Michael Mueller
www.pookas.de
Re: Reverse Rings [message #68218 is a reply to message #68167 ] Fri, 17 May 2013 11:28 UTC Go to previous messageGo to next message
Nice. That's quite the shine you managed to get on the stainless!
Re: Reverse Rings [message #68301 is a reply to message #68218 ] Sat, 18 May 2013 17:06 UTC Go to previous messageGo to next message
Thank you Glenn!
Michael Mueller
www.pookas.de
Re: Reverse Rings [message #68309 is a reply to message #68167 ] Sat, 18 May 2013 23:09 UTC Go to previous messageGo to next message
I wish I knew someone who owned some sandblasting equipment - I'd love to see how that would polish the metal!
Re: Reverse Rings [message #68320 is a reply to message #68309 ] Sun, 19 May 2013 14:16 UTC Go to previous messageGo to next message
Sandblasting and other media-blasting do not polish metals. They remove very small amounts of metal and leave a satin finish - coarseness dependent on media type, blasting velocity, and a few other parameters. Shotpeening will do much the same, but doesn't remove any material.
Re: Reverse Rings [message #68327 is a reply to message #68167 ] Sun, 19 May 2013 16:48 UTC Go to previous messageGo to next message
Interesting, thanks.
Re: Reverse Rings [message #68375 is a reply to message #68327 ] Mon, 20 May 2013 19:11 UTC Go to previous message
I'm thinking about to buy a sandblaster even if it's not working for polishing... just cause it's such a cool tool. Wink
Like this one... http://www.shapeways.com/forum/index.php?t=msg&&th=1 3080&goto=65137#msg_65137
Cheers!
Michael
Michael Mueller
www.pookas.de
Previous Topic:Impossible Twist by OSKAR
Next Topic:The I Love You Rose™
