Hoop for Pendant
Hoop for Pendant [message #68085] Wed, 15 May 2013 17:32 UTC Go to next message
I'm going to have this pendant printed in silver here at shapeways.
Should i print the model with the hoop that mounts to the chain or add that after?
Dont want to add a feature that is going to be problematic or may break off anyway at some point during the removal from the printer or in shipping.
Enclosed is a pic.
Thanks for looking
  • Attachment: Pendant.jpg
    (Size: 7.98KB, Downloaded 66 time(s))
Re: Hoop for Pendant [message #68096 is a reply to message #68085 ] Wed, 15 May 2013 20:30 UTC Go to previous messageGo to next message
avatar FabMeJewelry  is currently offline FabMeJewelry
Shapeways Crew
I don't know the dimensions but i would keep the hoop !
The hoops we use always turns out nicely as you can see in the picture below,
the hoop has a inside diameter of 3mm and is 1,25 mm thick.
index.php?t=getfile&id=32508&private=0
Wesley Günter - FabMeJewelry.com - Set a course, for the future ! *back on the forums ! x)
Re: Hoop for Pendant [message #68128 is a reply to message #68096 ] Thu, 16 May 2013 09:34 UTC Go to previous messageGo to next message
I would most definitely keep it in the design. Just stick to the design rules and you should be fine. If you'd like to do a search to see how pendants are typically done, the technical term for it is a bail and the the ring connected to the bail that is also sometimes used is called the jump ring.
Patterns For CNC
Re: Hoop for Pendant [message #68143 is a reply to message #68128 ] Thu, 16 May 2013 11:36 UTC Go to previous message
Very good then i will leave it. Thanks for the advice.
Previous Topic:Sunflower Oil on Parts?
Next Topic:Dipping Full Color Sandstone print in super glue?
