Home » Community » It arrived! » Quaternion julia set [math art]
Quaternion julia set [math art] [message #68019] Wed, 15 May 2013 00:28 UTC Go to next message
avatar RogerN  is currently offline RogerN
Well my 2nd model has arrived, and I love the appearance after painting it. I applied a single coat of acrylic paint with a metallic finish - no primer was necessary.
Quaternion Julia Set
index.php?t=getfile&id=32442&private=0
The mesh was generated by a custom C# program and then cleaned up a bit using Blender. Frankly I could go broke printing all the fractals I'm interested in... I've love to set up a shelf or two with nothing but mathematical art.
The biggest challenge I encountered was generating a nice mesh from a 3D isosurface which doesn't exceed the maximum number of vertices... I'm using a marching cubes algorithm for creating the mesh, and one of the downsides is that it uses the same vertex density all over rather than where you really need the detail.
Re: Quaternion julia set [math art] [message #68220 is a reply to message #68019 ] Fri, 17 May 2013 11:46 UTC Go to previous messageGo to next message
Very nice. What size is that and what acrylic spray in particular did you use?
Re: Quaternion julia set [math art] [message #68267 is a reply to message #68220 ] Fri, 17 May 2013 18:09 UTC Go to previous messageGo to next message
It's 3.5 inches long. The paint was not a spray, just a $2 bottle of acrylic from the local craft store. It's a metallic champagne color, Folk Art brand.
Re: Quaternion julia set [math art] [message #68269 is a reply to message #68267 ] Fri, 17 May 2013 18:42 UTC Go to previous messageGo to next message
avatar GarySG  is currently offline GarySG
You mentioned using Blender to touch up the models and that your models had too many polygons where it wasn't necesary. In the latest version of blender, when you go into sculpt mode, and turn on topology, there is an option to decrease the polygon count in only the areas you brush over. Just thought I'd let you know Smile
"Hm, I'm so hungry I could eat an entire cow. Gerard, fire up the printer!"
Re: Quaternion julia set [math art] [message #68272 is a reply to message #68267 ] Fri, 17 May 2013 20:15 UTC Go to previous messageGo to next message
RogerN wrote on Fri, 17 May 2013 18:09
Wow, even more impressive. I'm familiar with that brand and wasn't aware one could get this quality from it.
Re: Quaternion julia set [math art] [message #68359 is a reply to message #68019 ] Mon, 20 May 2013 15:42 UTC Go to previous message
You can also retopo your model after you get the sculpt done. That way you can reduce the poly count to a manageable level.
Ray
www.RayTomlinDesigns.com
Previous Topic:Another Turtle
Next Topic:Impossible Twist by OSKAR
