Guys how do you name this 3d printing option where instead of printing the whole solid body volume, it makes an internal triangular grid/mesh/porous structure inside in order to save material? Thanks
You cannot just 'name' that you want the model hollow as an option. You have to create the model as hollow.
The name you're looking for is "infill" or "scaffolding", depending on the software or printer that you are using. Infill is normally required for FDM printers, and none of the Shapeways printers are based upon FDM. The Shapeways printers themselves do not require Infill, but you may opt to add it to your design anyway so that your object is stronger. It's entirely possible to make a completely hollow object with the processes that Shapeways uses.
