Issues with manifold... [message #6808] Fri, 25 September 2009 05:26 UTC |
I've gone through the model bit by bit... I've covered up every hole, welded every vert, straightened all the normals... even done the cleanup check... still no luck... is there something wrong with it? Anyone with Maya 2010 can help would be most appreciated... also if anyone knows how to put Collada plugin into Maya 2010... it would be awesome...
Attachment: meMask.ma
(Size: 1.51MB, Downloaded 139 time(s))
| Re: Issues with manifold... [message #6809 is a reply to message #6808 ] Fri, 25 September 2009 08:33 UTC |
Hi there, I checked your file.
I think the problem was duplicated vertices. Usually, I solve this by going to Edit Mesh > Merge option box.
Check this screenshot:
Collada plugin for maya 2010 is not ready yet I think. When it will be, you can get it from the collada website: http://opencollada.org/download.html
I have attached your file by applying the merge vertices tool. Check it and see if it works now.
All the best,
DF
Attachment: meMask2.ma
(Size: 1.46MB, Downloaded 119 time(s))
http://shpws.me/DWg
| Re: Issues with manifold... [message #6818 is a reply to message #6809 ] Fri, 25 September 2009 15:07 UTC |
nice! i shall try it now... thank you!
| Re: Issues with manifold... [message #6819 is a reply to message #6808 ] Fri, 25 September 2009 15:56 UTC |
sigh... no change... i'll keep working on it... hopefully something will make it work
| Re: Issues with manifold... [message #6919 is a reply to message #6819 ] Wed, 30 September 2009 11:02 UTC |
I'd like to check that file for you, but I can't ready Maya files. Can you post it as STL? (Or mail it to bart@shapeways.com).
| Re: Issues with manifold... [message #6920 is a reply to message #6919 ] Wed, 30 September 2009 11:28 UTC |
i'll do that once i get home... currently at school
| Re: Issues with manifold... [message #7030 is a reply to message #6919 ] Fri, 02 October 2009 17:53 UTC |
sry for replying so late... here's the file at a STL
Attachment: meMask.stl
(Size: 688.22KB, Downloaded 81 time(s))
| Re: Issues with manifold... [message #7064 is a reply to message #7030 ] Sun, 04 October 2009 03:11 UTC |
Try this.
(Size: 636.80KB, Downloaded 75 time(s))
[Updated on: Sun, 04 October 2009 03:12 UTC]
Re: Issues with manifold... [message #7069 is a reply to message #7064 ] Sun, 04 October 2009 13:48 UTC |
yes! finally it worked ... but its too small hehe... i'll resize it in Accutrans and re-upload... thanks you!!
