inverse normals
Discussion in 'Design and Modeling' started by 324165_deleted, May 1, 2013.
  1. I'm a student in architecture and the attached file is an attempt to create part of my physical model - the part I would have a hard time building with sticks or wire or chipboard.
    Using Netfabb, I've worked manually to reverse the normals of the red faces. Now I'm left with the red faces on the helical truss, but the amount of work to reverse all these tiny faces is tremendous and I was wondering if you knew of a software that can do that for me. Netfabb identifies all these faces and colors them red, why can't it reverse them as well?
    The trick on that helical truss is that it's made of hollow tubes so there might be inverse normals within the truss itself but I can't see them.
    I'm happy to turn that truss into a filled tube (or rod) if that helps with the 3d printing (although I realize it would be more expensive).
    I appreciate your help and advice on this matter!
  2. Youknowwho4eva
  3. I did use the link and followed the steps, but Netfabb doesn't fix the "invalid orientation". It only colors the faces red. and since my model isn't totally red, it's not helpful.
    I used Meshlab in the first step (to convert to stl), but not to fix the model. will try if it's helpfull.
  4. JACANT
    JACANT Well-Known Member
    What software did you use to create the original?
    It may be easier to fix by someone if you upload the original file.
  5. Youknowwho4eva
    Are you sure it's invalid orientation and not self intersections? It doesn't turn red for me till I detect self intersections.
  6. stonysmith
  7. I used ArchiCAD.
    But I think I figured out what the problems were. I replaced a couple of objects by solid morphs and I think it took care of the problem.
  8. I just did that after looking for the solution to having too many shells.
    I'm finally good with:
    -0 Holes
    - 0 Border edges
    - 0 Invalid orientations
    -length of within tolerance
    - Closed Surface
    However, I'm not sure where to check that I have a Positive Volume.
    And I have 108 shells.
    I still have many degenerated faces based on the Netfabb view settings.
    but it doesn't seems to be a problem from what I read in the tutorial.
    thank you all for your help!
    I hope it's the end of manipulating that file!
  9. stop4stuff
    stop4stuff Well-Known Member
    Sorry, a bit late here. Accutrans3D has a simple 'Preset All' normals function and fixes exactly your original issue in a click, providing there's no other integrity issues,
