Home » Support » 3D Design » Non Manifold... but no non-manifold found in Blender
Non Manifold... but no non-manifold found in Blender [message #6707] Mon, 21 September 2009 03:33 UTC Go to next message
avatar winglessbuzzard@gmail.com  is currently offline winglessbuzzard@gmail.com
In the attached file, I cannot find a non-manifold area in the object Cube.003. I've exported it as x3d and attempted to upload it to shapeways twice. Each time I get an error back saying the object is non-manifold. Is the .blend --> .x3d format conversion causing it to be non-manifold?
Re: Non Manifold... but no non-manifold found in Blender [message #6709 is a reply to message #6707 ] Mon, 21 September 2009 04:31 UTC Go to previous messageGo to next message
Some of the bottom facing normals are around the wrong way Smile
index.php?t=getfile&id=1423&private=0
  • Attachment: normals.JPG
    (Size: 21.50KB, Downloaded 347 time(s))
Re: Non Manifold... but no non-manifold found in Blender [message #6725 is a reply to message #6707 ] Mon, 21 September 2009 12:13 UTC Go to previous messageGo to next message
How do I find the inverted normals and fix them? I couldn't find any 'inverted normals' tutorial on this site. I cannot identify any inverted normals in Blender (unless I'm doing something wrong, which is very likely).
Re: Non Manifold... but no non-manifold found in Blender [message #6737 is a reply to message #6725 ] Mon, 21 September 2009 16:06 UTC Go to previous messageGo to next message
avatar afrodri  is currently offline afrodri
I'd recommend checking out MiniMagics - its a free program which does a good job of finding inverted normals and non-manifold edges.
Re: Non Manifold... but no non-manifold found in Blender [message #6738 is a reply to message #6737 ] Mon, 21 September 2009 16:58 UTC Go to previous messageGo to next message
Are you sure that MiniMagics still allows editing? I downloaded and installed the program and it refers me to "Magic RP" to do all my editing/fixing. Or should I use minimagics just for finding the problems and edit the objects in Blender.
[Updated on: Mon, 21 September 2009 17:01 UTC]
Re: Non Manifold... but no non-manifold found in Blender [message #6740 is a reply to message #6738 ] Mon, 21 September 2009 17:20 UTC Go to previous messageGo to next message
MiniMagics doesn't do any fixing itself, but it does a good job of displaying where the inverted normals or bad edges are.
Re: Non Manifold... but no non-manifold found in Blender [message #6802 is a reply to message #6740 ] Thu, 24 September 2009 18:20 UTC Go to previous messageGo to next message
Thanks guys! Minimagics is awesome!!!.. I wish they could build a Minimagics type script into Blender. Anyway, I got it fixed and uploaded, thanks!
icon3.gif  Re: Non Manifold... but no non-manifold found in Blender [message #6804 is a reply to message #6802 ] Thu, 24 September 2009 21:03 UTC Go to previous messageGo to next message
Another useful tip:
configure Blender to draw the face normals when editing the file.
That way you can see them in blender and in this case you would probably have to load/import the x3d file and check the results as well.
Go to Editing mode and open up the mesh editing buttons panel.
In the Mesh Tools More section there's a button labeled "Draw normals". Make sure it's selected/active.
The normals should point out from the "solid material area".
I use it all the time to make sure that the model won't spaz out when/if I add the SubSurf modifier.
(If you see a face normal where there should just be a face edge you have a face that is not visible to the eye but it effects the subsurf division quite clearly.. a common problem when a noob like me tries to extrude a face/edge and forgets to move it away from its original location)
The "Draw Vnormals" button does the same for the vertice normals, which may or may not be useful...
[Updated on: Thu, 24 September 2009 21:06 UTC]
Re: Non Manifold... but no non-manifold found in Blender [message #6807 is a reply to message #6804 ] Thu, 24 September 2009 23:25 UTC Go to previous message
avatar clintbellanger  is currently offline clintbellanger
(in Blender)
With some meshes, the option "Recalculate Outside Normals" cleans up these flipped faces.
Select the mesh, [tab] to enter Edit mode. Click the "Mesh" menu on the 3D viewport, then Normals -> Recalculate Outside.
Doesn't work for all meshes, but manifold meshes should work most of the time.
Previous Topic:Whole object is non-manifold, 20.3MB stl file
Next Topic:Getting started?
