Another useful tip:
configure Blender to draw the face normals when editing the file.
That way you can see them in blender and in this case you would probably have to load/import the x3d file and check the results as well.
Go to Editing mode and open up the mesh editing buttons panel.
In the Mesh Tools More section there's a button labeled "Draw normals". Make sure it's selected/active.
The normals should point out from the "solid material area".
I use it all the time to make sure that the model won't spaz out when/if I add the SubSurf modifier.
(If you see a face normal where there should just be a face edge you have a face that is not visible to the eye but it effects the subsurf division quite clearly.. a common problem when a noob like me tries to extrude a face/edge and forgets to move it away from its original location)
The "Draw Vnormals" button does the same for the vertice normals, which may or may not be useful...
