Simplest job on here... Just need someone to model a pyramid for me
Simplest job on here... Just need someone to model a pyramid for me [message #66677] Tue, 23 April 2013 02:19 UTC Go to next message
avatar Pablo123  is currently offline Pablo123
I am guessing is should be about as simple a request as you will see: just need someone to generate a model of a pyramid for shapeways. Dimensions of the square base is 4 inches a side, and each face a 55-55-70 triangle. If my high school math is correct, the vertical sides of the triangle would be 3.5 inches.
Re: Simplest job on here... Just need someone to model a pyramid for me [message #66680 is a reply to message #66677 ] Tue, 23 April 2013 04:26 UTC Go to previous messageGo to next message
To paraphrase Teddy Roosevelt: nothing worth doing is easy, nothing easy is worth doing.
At that size, the object is going to be rather expensive.
You could save a large amount of money if you make the pyramid hollow.
But, that causes the question: What Material would you like to print it in?
Each material has a different wall thickness requirement.
The attached file is 4x4x3.5 and is completely solid.
It'd cost about $425.00 to print as a solid in WSF, possibly somewhere around $70 if it was hollow.
Edit: you actually want a pyramid that is 2.86" from the base to the peak.
  • Attachment: Pyramid.stl
    (Size: 0.38KB, Downloaded 68 time(s))
[Updated on: Tue, 23 April 2013 04:40 UTC]
Re: Simplest job on here... Just need someone to model a pyramid for me [message #66796 is a reply to message #66680 ] Wed, 24 April 2013 12:53 UTC Go to previous message
Thank you very much. I was going to make something for my nephew in plastic, but at those costs, it is obvious I should go back to manual. I doubt he is going to appreciate a set of $70 toy pyramids!
If I ever get something that merits this kind of work and cost I will let you know. Thank you again.
Previous Topic:Need a favor
Next Topic:Need a favor
