Exporting to X3D from Blender
Exporting to X3D from Blender [message #66488] Sat, 20 April 2013 00:36 UTC Go to next message
avatar GarySG  is currently offline GarySG
I'm currently trying to learn to use blender for it's full color benefits, but i'm having trouble exporting the model. when I export the file as an X3D file type, and upload it, it uploads without a texture. I'm new to the program, but I can't quite understand what I could be missing. I looked up tutorials on UV wrapping, that didn't work, nor did simply assigning the object a blanket material.
Thanks for any help Confused
[Updated on: Sat, 20 April 2013 15:06 UTC]
"Hm, I'm so hungry I could eat an entire cow. Gerard, fire up the printer!"
Re: Explorting to X3D from Blender [message #66497 is a reply to message #66488 ] Sat, 20 April 2013 06:22 UTC Go to previous messageGo to next message
when you upload an x3d file where the object has a texture, you must create a zip file with the model file AND the texture file in and upload the zip file to SW.
Put your model file in a directory and then put the texture file in the same directory. Select them both and then 'Send to' a 'Compressed (Zipped) folder'.
Just as a check you can also give your object a material with a colour and upload that directly as x3d, without a texture. It will be just one colour but you will have a coloured object in SW.
Yet another approach which does not require zipping is vertex painting: I'm not too familiar with this, but it does work.
Good Luck!!
Re: Explorting to X3D from Blender [message #66524 is a reply to message #66497 ] Sat, 20 April 2013 15:57 UTC Go to previous messageGo to next message
Thanks for the pointers Very Happy
I've painted it now in vertex paint, but I've yet again hit a snag. It uploaded to the site without any color, yet offers it in full-color sandstone Confused
Am I supposed to save the paint job as the model's texture somehow?
[Updated on: Sat, 20 April 2013 15:58 UTC]
Re: Exporting to X3D from Blender [message #66531 is a reply to message #66488 ] Sat, 20 April 2013 16:36 UTC Go to previous messageGo to next message
Scratch that, after watching a tutorial online, I realized that I had to assign a material to the model, and then select the option to use the vertex paint for the material.
So I did indeed upload the colored model to SW successfully, thank you for the assistance Razz
Last thing I have to do is find out why some of the faces aren't being painted, leaving black triangles spotted all over the model. Hm Confused Youtube, here I come Very Happy
Re: Exporting to X3D from Blender [message #66534 is a reply to message #66531 ] Sat, 20 April 2013 17:00 UTC Go to previous messageGo to next message
Depends on where you see the black triangles - the rotating 3d preview is buggy. Best check with a vrml/x3d viewer such as view3dscene.
Re: Exporting to X3D from Blender [message #66549 is a reply to message #66534 ] Sat, 20 April 2013 19:43 UTC Go to previous messageGo to next message
It isn't looking correct in View3DScene either, it's like those faces are invisible in that program, and blacked out on the site. Is there any way I can ask customer service to look at how the 3D model will print in full color SS before I actually order it? I wouldn't want to order it with the black triangles Confused
I looked for tutorials for fixing the black faces, but couldn't find any :/
Re: Exporting to X3D from Blender [message #66551 is a reply to message #66549 ] Sat, 20 April 2013 20:21 UTC Go to previous messageGo to next message
It could be that the black triangles are inside out.
Try 'Ctrl N' to recalculate outside normals
[Updated on: Sat, 20 April 2013 20:21 UTC]
Re: Exporting to X3D from Blender [message #66552 is a reply to message #66551 ] Sat, 20 April 2013 20:29 UTC Go to previous messageGo to next message
I tried Ctr+N, entire sections of the model dissappeared.
I feel like those faces are actually missing, when I view it in edit mode, triangles are see-through. Is there a repair function? I think that must be what SW is doing, repairing and filling those missing triangles, but obviously not having a color to go on them, because they weren't there to start with.
Re: Exporting to X3D from Blender [message #66553 is a reply to message #66552 ] Sat, 20 April 2013 20:33 UTC Go to previous messageGo to next message
Here, I've attached the file, if anyone would like to give it a go. I'm sure there's some simple command that could fix it.. hopefully.
EDIT: If it makes any difference, I used sculpt to create it.
[Updated on: Sat, 20 April 2013 20:34 UTC]
Re: Exporting to X3D from Blender [message #66554 is a reply to message #66553 ] Sat, 20 April 2013 20:53 UTC Go to previous messageGo to next message
In my experience, if the color preview isn't right, then it won't print correctly either.
Re: Exporting to X3D from Blender [message #66555 is a reply to message #66554 ] Sat, 20 April 2013 21:00 UTC Go to previous message
http://www.shapeways.com/model/1052215/creepy-12-color-almos t-done.html?li=my-models&key=48aad02a047135fe7fffdf41824 fec15
I'm not sure what to do, to be honest. It's odd, when I render it in Blender, it's fine.
index.php?t=getfile&id=30907&private=0
  • Attachment: demon_02.png
    (Size: 109.43KB, Downloaded 100 time(s))
Previous Topic:Welding of 3D printed jewelry
Next Topic:Pricing in euros
