G-Shock watch case cover
G-Shock watch case cover [message #66226] Tue, 16 April 2013 23:56 UTC Go to next message
avatar TheCeladon  is currently offline TheCeladon
I created a G-shock watch case cover. This was the first print and it was slightly off. I had to grind away some material to make it fit. The next print should be exact. It was printed in stainless steel.
index.php?t=getfile&id=30715&private=0index.php?t=getfile&id=30714&private=0index.php?t=getfile&id=30713&private=0index.php?t=getfile&id=30712&private=0
Re: G-Shock watch case cover [message #66243 is a reply to message #66226 ] Wed, 17 April 2013 07:10 UTC Go to previous messageGo to next message
avatar Innovo  is currently offline Innovo
Good work. It should be even nicer if polished.
Innovation & Design
http://www.byinnovodesign.com/
www.facebook.com/byInnovoDesign
Re: G-Shock watch case cover [message #66252 is a reply to message #66226 ] Wed, 17 April 2013 12:00 UTC Go to previous messageGo to next message
avatar mygadgetlife  is currently offline mygadgetlife
Knowledge Expert
I like this. Would be great in polished gold if you wanted to add bling to your Casio Smile
Come join my 3D printing adventures over at facebook.com/mygadgetlife
Re: G-Shock watch case cover [message #66256 is a reply to message #66252 ] Wed, 17 April 2013 13:20 UTC Go to previous messageGo to next message
Very, very nice.
But beware, for ss from the materials page: Accuracy: ± 2mm
Re: G-Shock watch case cover [message #66265 is a reply to message #66256 ] Wed, 17 April 2013 15:34 UTC Go to previous messageGo to next message
Looks awesome,
AmLachDesigns, the Accuracy: ± 2mm depends on the size of the print, at that scale it would be microns not mm.
Keep up the great work TheCeladon
Duann Scott,
Re: G-Shock watch case cover [message #66268 is a reply to message #66265 ] Wed, 17 April 2013 16:38 UTC Go to previous messageGo to next message
Fair enough - what are the various tolerances at various scales? And when will the materials sheet change to show this?
Re: G-Shock watch case cover [message #66270 is a reply to message #66265 ] Wed, 17 April 2013 16:40 UTC Go to previous messageGo to next message
The printed length of the object was off by .25mm. Not very much but enough to prevent the part from fitting as I designed it to fit exactly. I want to make adjustments to the drawing and give it another go. Overall though it came out pretty well for a first test.
Re: G-Shock watch case cover [message #66271 is a reply to message #66270 ] Wed, 17 April 2013 16:41 UTC Go to previous messageGo to next message
Is my maths correct - 250 microns?
Re: G-Shock watch case cover [message #66275 is a reply to message #66271 ] Wed, 17 April 2013 17:01 UTC Go to previous message
yes that is correct. 250 microns.
Previous Topic:Bass Drum Ring
Next Topic:Kneeling Woman sculpture
