Home » Support » 3D Applications » Format conversion with MESHLABS
Format conversion with MESHLABS [message #254] Tue, 17 June 2008 07:27 UTC Go to next message
avatar jnge.100  is currently offline jnge.100
Dear All,
I only recently heared about Shapeways, and joined yesterday. As an 3D enthusiast (hobby, not profession) I really would like some real 3d versions of my virtual models.
Since I usually generate OBJ or STL files, I was looking for an open source convertor (into COLLADA). I found MESHLABS (meshlabs.sourceforge.net), which can do the job. With MESLABS, besides conversion and scaling, even various modifactions can be done.
So maybe MESHLABS can be an opensource alternative to ACCUTRANS 3D. Myself, I will try and upload an model converted by MESHLABS soon.
Best Regards Hans
Re: Format conversion with MESHLABS [message #255 is a reply to message #254 ] Tue, 17 June 2008 11:13 UTC Go to previous messageGo to next message
Hi Hans,
I've tried MeshLAB, but found that the scaling transformations aren't applied to the Collada exports :-/ (even when you 'freeze' the object). With some luck, we'll have proper STL support later this week though - MeshLAB will definitely be useful for that!
Re: Format conversion with MESHLABS [message #256 is a reply to message #254 ] Tue, 17 June 2008 13:54 UTC Go to previous messageGo to next message
Hello Bart,
Thanks for your quick response.
(indeed it's MeshLab and not Meshlabs, sorry)
STL support would be great.
OBJ converting in STL is also possible, and it would avoid the "COLLADA hassle".
Looking forward to hear from you, if you got STL support up and running. Thank you.
Hans
Re: Format conversion with MESHLABS [message #260 is a reply to message #256 ] Tue, 17 June 2008 16:29 UTC Go to previous messageGo to next message
We'll let you know, don't worry!
PS: Oh, and I certainly didn't write 'Meshlab' that way to point out a spelling mistake, but now that I see it back it does look that way. Silly me!
Re: Format conversion with MESHLABS [message #263 is a reply to message #254 ] Wed, 18 June 2008 09:33 UTC Go to previous messageGo to next message
Hello Bart,
Sorry to bother you once more regarding Meshlab.
I did a quick test with Meshlab version 1.1.1 (March 2008).
I started with a simple cube of size 1 (Test_cube.obj)
Next, opened it in Meshlab and converted it into Collada (Test_cube.dae) and closed Meshlab.
Next I opened this dae file in Meshlab and scaled it with factor 8 (freeze/close), and saved it as (Test_cube_size_8.dae) and closed Meshlab again.
Next I opened the scaled dae file in Meshlab and looked at the bounding box, it showed indeed a 8x8x8 size.
Finally I converted Test_cube_size_8.dae into Test_cube_size_8.obj. If I open this obj file in a 3D application, it indeed has size 8x8x8. So for sure this dae file contained some scaling information which was correctly applied to the obj file. But the question remains if the dae file also has size 8x8x8.
Since I can not open a Collada file in my 3D-Applications, can you please check the attached file (Test_cube_size_8.dae) for it's size in your "printing software"?
Thanks in advance. Hans
Re: Format conversion with MESHLABS [message #264 is a reply to message #263 ] Wed, 18 June 2008 13:20 UTC Go to previous messageGo to next message
Hi Hans,
hmmm, odd. I managed to get some fairly decent results by converting from STL to Collada with Meshlab today as well, maybe I did something wrong last time. The easiest way to test is to just upload the model to Shapeways and set it to 'Private' (unless you want your public profile to be filled with cubes). Anyway, that's what I did and I got the following result in the mail:
"The size is 1600 x 1600 x 1600 ( h x b x d)."
It looks like you're almost there, but one Blender unit translates to 1 meter. (A default Blender cube is not 1x1x1, but 2x2x2). So resizing in Meshlab to 0.01 will probably to the trick?
Re: Format conversion with MESHLABS [message #27943 is a reply to message #264 ] Fri, 20 May 2011 21:09 UTC Go to previous messageGo to next message
avatar eTraxx  is currently offline eTraxx
Ok. Tried scaling my .dae file in MeshLabs. I see the 'Close' .. but for the life of me .. where the heck is the 'Freeze' button? Either I'm crazy (could be) or I got shortchanged a button.
Re: Format conversion with MESHLABS [message #30549 is a reply to message #27943 ] Sun, 10 July 2011 01:20 UTC Go to previous message
The command you are looking for is in the filters menu: Normals, Curvatures And Orientation->Freeze Current Matrix. There really should be a freeze button since it is used constantly.
Previous Topic:MeshLab: Render obj file with my own computed normals
Next Topic:Unbiased rendering
