Home »  » Post Production Techniques » Dyeing polished white strong and flexible
Dyeing polished white strong and flexible [message #65346] Tue, 02 April 2013 13:43 UTC Go to next message
I have been dyeing Shapeways WSF material for two years now using RIT fabric dyes. Recently, I have been having more and more problems with the process. A friend had heard from the Disk Golf community that RIT has changed their dyes recently, and the new dyes do now work as well on plastics. I have found that the new formula RIT dyes, which have a code on the top which begins with "ND", do not work very well for WSF. In addition, polished WSF in general is more difficult to dye compared with ordinary (unpolished) WSF.
What other dyes have people used? What dyes work best on polished WSF? The dye that Shapeways uses seems to be very nice. Any hint as to who makes this dye?
Here in the USA, Jacquard dyes are an alternative to RIT. They make iDye Poly, which is specifically for synthetic fabrics (so probably good for nylon), as well as a line of "acid dyes". Has anyone experience with either of these?
[Updated on: Tue, 02 April 2013 13:53 UTC]
Re: Dyeing polished white strong and flexible [message #65359 is a reply to message #65346 ] Tue, 02 April 2013 15:23 UTC Go to previous messageGo to next message
Check out 58771 it msy be useful.
Re: Dyeing polished white strong and flexible [message #65380 is a reply to message #65359 ] Tue, 02 April 2013 22:37 UTC Go to previous messageGo to next message
Thanks, that thread is very useful. That thread only discusses dyeing in black. I am interested in all colors!
Re: Dyeing polished white strong and flexible [message #65393 is a reply to message #65380 ] Wed, 03 April 2013 06:14 UTC Go to previous messageGo to next message
Shows what I know - to me dying is dying...
All non-white strong and flexible products sold by Shapeways start off white and are dyed, by SW. The link I gave is some people doing the dying themselves of wsf.
[Updated on: Wed, 03 April 2013 11:52 UTC]
Re: Dyeing polished white strong and flexible [message #65913 is a reply to message #65393 ] Wed, 10 April 2013 17:20 UTC Go to previous messageGo to next message
Over the past week I have been dying polished WSF using Jacquard acid dyes. The results have been somewhat mixed. Yellow sun turned out beautifully and perfectly evenly. Chestnut brown is OK but the color is a bit uneven.
One thing that seems to happen quite often in any dying process with polished WSF is that the color can appear very uneven during the dying process. This unevenness is always oriented with the print orientation. The "top" of the pieces as printed appears much lighter than the "bottom". The interesting thing is that most times this unevenness goes away after the parts dry, in other words it is only visible when the pieces are wet. And for some reason I have never seen it happen with unpolished WSF.
I have not seen any unevenness in the Shapeways dyed polished WSF. Perhaps I will try wetting some of these pieces to see if it becomes visible.
Re: Dyeing polished white strong and flexible [message #66577 is a reply to message #65913 ] Sun, 21 April 2013 14:21 UTC Go to previous messageGo to next message
Here are some photos of my latest tests. ALL material shown is polished WSF. The first two pieces were dyed by Shapeways.
index.php?t=getfile&id=30918&private=0
Left: purple as dyed by Shapeways (this is polished WSF dyed purple)
Right: coral red as dyed by Shapeways
These are both excellent, very uniform and bright colors!
[Updated on: Sun, 21 April 2013 14:39 UTC]
Re: Dyeing polished white strong and flexible [message #66578 is a reply to message #66577 ] Sun, 21 April 2013 14:24 UTC Go to previous messageGo to next message
Next we have some less successful colorings ...
index.php?t=getfile&id=30919&private=0
Top left: Jacquard Acid 601 Yellow Sun, best of the bunch! The color is very even.
Top right: Jacquard Acid 632 Chestnut, dark and uneven, although the uneveness doesn't show so much in the photos.
Bottom left: Jacquard Acid 627 Kelly Green, despite boiling for 45 minutes, the color is way too light, a strange neon green.
Bottom right: Jacquard iDye Poly 452 Green, way too dark in only 5 minutes, barely identifiable as green. Dye concentration may have been too high.
Re: Dyeing polished white strong and flexible [message #66579 is a reply to message #66578 ] Sun, 21 April 2013 14:30 UTC Go to previous messageGo to next message
Blue, anyone?
index.php?t=getfile&id=30920&private=0
Top left: RIT Royal Blue, the new formula. Dark and uneven, looks better in this photo than in reality.
Top right: Jacquard Acid 623 Brilliant Blue. Excellent color, slightly uneven. Overall the best blue.
Bottom left: Jacquard iDye Poly Blue. Very even and nice color. More shifted towards red than the previous two, appears violet in comparison.
Bottom right: Jacquard Acid 617 Cherry Red. Excellent color, but more pink or fuchsia than red.
[Updated on: Sun, 21 April 2013 14:37 UTC]
Re: Dyeing polished white strong and flexible [message #66590 is a reply to message #66579 ] Sun, 21 April 2013 20:08 UTC Go to previous messageGo to next message
Reds:
index.php?t=getfile&id=30937&private=0
Top left: Jacquard Acid 617 Cherry Red. Excellent color, but more pink or fuchsia than red.
Top right: Jacquard Acid 618 Fire Red. Poor color saturation. Even, but more like a salmon color.
Bottom: Jacquard iDye Poly Red. Very even and nice color. A bit dark.
[Updated on: Sun, 21 April 2013 20:09 UTC]
Re: Dyeing polished white strong and flexible [message #66794 is a reply to message #66590 ] Wed, 24 April 2013 12:30 UTC Go to previous messageGo to next message
avatar rosethun@yahoo.com  is currently offline rosethun@yahoo.com
Thanks for the pictures; I will have to try- even with uneven colors they are quite gorgeous and you could do an interesting dip dye process too.
Re: Dyeing polished white strong and flexible [message #66801 is a reply to message #66794 ] Wed, 24 April 2013 13:35 UTC Go to previous messageGo to next message
Strange how the photos always seem to make the colors look better than they appear in person. The three blues, for example, are quite different, but the photo makes them look very similar.
Dip dye would be quite tricky, given that the mixture is boiling (generally)! But an interesting idea!
Re: Dyeing polished white strong and flexible [message #66912 is a reply to message #66801 ] Fri, 26 April 2013 15:22 UTC Go to previous messageGo to next message
Purples:
index.php?t=getfile&id=31248&private=0
Top left: Jacquard Acid 612 Lilac. Good color but a bit light. This is the only one that looks purple to me.
Top right: Jacquard Acid 613 Purple. Good color but is virtually identical to blue.
Bottom left: Jacquard Acid 614 Violet.. Slightly redder but still appears basically blue.
Bottom right: Jacquard Acid 623 Brilliant Blue.
This photo was taken outdoors. Under artificial light all 4 colors appear identical in a photograph!
Re: Dyeing polished white strong and flexible [message #67391 is a reply to message #66912 ] Fri, 03 May 2013 13:35 UTC Go to previous messageGo to next message
more colors in iDye Poly ...
index.php?t=getfile&id=31749&private=0
Top left: iDye Poly brown, nice and even, best brown yet.
Top right: iDye Poly Black, very dark and even, best black.
Bottom: iDye Poly Green, best green yet! I show this color above but before the dye concentration was too high.
Re: Dyeing polished white strong and flexible [message #69536 is a reply to message #67391 ] Mon, 10 June 2013 14:52 UTC Go to previous messageGo to next message
After much experimentation, I now have a set of 7 colors that I am happy with. Besides nice color, one of my criterion is that the colors appear different from one another. Here are the 7 Jacquard dyes I now use:
Blue: acid dye Brilliant Blue
Red: acid dye Cherry Red
Yellow: acid dye Yellow Sun
Purple: iDye poly Violet
Green: iDye poly Green (still looking for a better green)
Brown: iDye poly Brown
Black: iDye poly Black
Re: Dyeing polished white strong and flexible [message #72825 is a reply to message #69536 ] Thu, 08 August 2013 18:57 UTC Go to previous messageGo to next message
avatar NormL  is currently offline NormL
Do you mind saying what concentration, duration and temperature you used for the green poly?
Re: Dyeing polished white strong and flexible [message #72958 is a reply to message #72825 ] Mon, 12 August 2013 14:30 UTC Go to previous messageGo to next message
NormL wrote on Thu, 08 August 2013 18:57
The trick with the green seems to be very low dye concentration. I only use 1/10 to 1/20'th of a dye packet in 1 liter of water, whereas with other colors I can use up to 1/4 of a dye packet. I boil the parts for about 5 minutes for green, whereas for other colors the time can be considerably longer. I live at altitude 1600m, so my boiling temp is reduced by 6 degrees C or so.
Re: Dyeing polished white strong and flexible [message #72960 is a reply to message #72958 ] Mon, 12 August 2013 14:39 UTC Go to previous messageGo to next message
Thank you! My Washington "The Evergreen" State elevation maps are very appreciative. They just don't look right in red or black.
Re: Dyeing polished white strong and flexible [message #72961 is a reply to message #72960 ] Mon, 12 August 2013 15:07 UTC Go to previous messageGo to next message
I am still looking for a better green. The iDye Poly Green still seems too dark to me, even in low concentrations, I would like something brighter. I had high hopes recently for the new color: "iDye Poly Kelley Green", but I tried it recently and I think I again overdosed the dye. It came out too dark. It is all too easy to go overboard on green in particular.
Shapeways used to have a green that was quite bright, but the color was discontinued. I am not sure what dye brand they used ...
[Updated on: Mon, 12 August 2013 15:07 UTC]
Re: Dyeing polished white strong and flexible [message #73226 is a reply to message #72961 ] Sat, 17 August 2013 21:50 UTC Go to previous messageGo to next message
They are still a little wet, but, you were not kidding about how quick they take color!
http://www.imgtree.net/files/xfgu4fq77zs2b9rcytki.jpg
This was my first test on the Evergreen State, LOL
Re: Dyeing polished white strong and flexible [message #73476 is a reply to message #73226 ] Thu, 22 August 2013 14:47 UTC Go to previous messageGo to next message
I do see what you mean about needing a better green. It is a little too drab in person. It works fine for a cartoon about a state, but, for just a green object it does need to be brighter. Thank you for your help
Re: Dyeing polished white strong and flexible [message #73514 is a reply to message #73476 ] Thu, 22 August 2013 20:19 UTC Go to previous messageGo to next message
NormL wrote on Thu, 22 August 2013 14:47
Is your model normal WSF, or polished WSF? Normal WSF absorbs dye better than the polished WSF, and thus will become darker even faster. My parts above are all polished.
In any case, I agree we need a brighter green.
Do you have a "Colorful Colorado" version of this? I live in Colorado ... you could print it in color Sandstone ...
[Updated on: Thu, 22 August 2013 20:22 UTC]
Re: Dyeing polished white strong and flexible [message #73515 is a reply to message #73514 ] Thu, 22 August 2013 20:20 UTC Go to previous messageGo to next message
Normal rough old WSF
Re: Dyeing polished white strong and flexible [message #73666 is a reply to message #73515 ] Mon, 26 August 2013 03:59 UTC Go to previous message
Yes, Colorado is on it's way
Previous Topic:Any way to clean multicolor sandstone?
Next Topic:Any recommendations for a painter to commission?
