| Interlocked shapes [message #6482] Sat, 12 September 2009 17:30 UTC |
This is my third (and last) post in this section about the objects I received on Friday. There is more to show, but I will probably post about the other objects later, in other sections (problems of design or problems of printing).
I really like interlocked shapes, and I guess 3D printing is one of the best way to actually create them.
So to begin, here are two Brunnian (or Borromean) links.
First the famous Brunnian rings or Brunian circles (seen in the coat of arms of the Borromeo family).
Such an interlocking cannot be obtained with standard rings, so I cheated a little bit by giving them a kind of ondulation. All the 3 rings have the same shape and have a nice symmetry (I put the ondulation even where not necessary to keep this symmetry).
The property of all brunnian links is that that even though the 3 links are interlocked, no two of them are actually linked: as a consequence, if you remove (break) just one of them then the two other ones will fall apart.
The Brunian links with each link having an ellipse shape have the same topology as the previous one but don't required any trick.
It is an interesting object to play with.
And last but not least, I am really happy to have received the Dod'net: it is a network of interlocked dodecahedra.
The printing is just FANTASTIC: there is no defect. It is just perfect.
Here are some details.
Of course it is probably very fragile (I did not try to stress it), but I am amazed that such a structure could be printed and arrived with no damages!
Congratulation to all those who manipulated it without breaking it (including myself )!
Attachment: Circles1.jpg
(Size: 142.97KB, Downloaded 1670 time(s))
Attachment: Circles2.jpg
(Size: 110.22KB, Downloaded 1615 time(s))
Attachment: Links.jpg
(Size: 136.93KB, Downloaded 1814 time(s))
Attachment: Dodnet1.jpg
(Size: 145.19KB, Downloaded 1607 time(s))
Attachment: Dodnet2.jpg
(Size: 109.82KB, Downloaded 1587 time(s))
[Updated on: Sun, 13 September 2009 05:54 UTC] So many things to design, so little time...
| Re: Interlocked shapes [message #6507 is a reply to message #6482 ] Sun, 13 September 2009 23:19 UTC |
I wonder if you could add some kind of cut that would allow the rings to be disconnected? Something like a carabiner gate used for rock climbing? The flexibility of WSF could help you out here.
| Re: Interlocked shapes [message #6511 is a reply to message #6507 ] Mon, 14 September 2009 07:03 UTC |
That's a good idea, and only one cut on one circle should be enough. Unfortunately, it is not so easy, since the special shape of the rings prevent them from rotating: so it would be impossible to position the cut to a particular place (the cut is stuck to its initial position).
I have to think about it: perhaps it could be done by modifying the design, with for instance one of the ring being planar?
| Re: Interlocked shapes [message #6721 is a reply to message #6482 ] Mon, 21 September 2009 10:55 UTC |
O.K. wow. The explanations make threads more interesting than just pictures especially for we not-so-mathematically/spatially-minded.
| Re: Interlocked shapes [message #7056 is a reply to message #6746 ] Sat, 03 October 2009 17:14 UTC |
That's incredible where fascination can lead to!
Actually, your design seems a little bit different from mine: the thickness seems different depending on where you are along the ellipse, while mine has always the same section. Or perhaps is it an illusion due to the camera?
Anyway, the links look great in Blue Jeans.
I also like the five interlocked tetrahedra (I have seen in another post that you also have a multicolored version that is even more beautiful).
By the way, I have designed a new shape made of interlocked "rounded stars".
I will show it as soon as it arrives. Stay tuned!
| Re: Interlocked shapes [message #8453 is a reply to message #8448 ] Sun, 20 December 2009 17:37 UTC |
No side touching. At the contrary, you must keep some minimal distance between the different parts to avoid they get fused during printing.
This distance depends on the area that is in "quasi-contact". The larger the area, the larger the clearance.
If I had to give some values, I would say that:
- 0.5 mm is probably the minimum for Detail Material
- 0.75 mm the minimum for Strong and Flexible material.
- 1 mm should be safe whatever material.
Please if someone has a different experience, do correct my statements.
| Re: Interlocked shapes [message #34224 is a reply to message #6482 ] Tue, 13 September 2011 20:23 UTC |
are these possible in metal? it isn't clear with the latest metal design rules...
| Re: Interlocked shapes [message #34225 is a reply to message #6482 ] Tue, 13 September 2011 20:25 UTC |
Unfortunately no. Silver no way, stainless used to but no more. The pieces are just too fragile in their green stage. You could make them connected with a sprue that you could then cut off when you receive it.
| Re: Interlocked shapes [message #34226 is a reply to message #34225 ] Tue, 13 September 2011 20:44 UTC |
how thin / thick a sprue would be necessary for this to work?
| Re: Interlocked shapes [message #34230 is a reply to message #34229 ] Tue, 13 September 2011 22:29 UTC |
given the example design Brunnian Links, say 5cm x 8cm (1cm thick), would the design work with spurs connecting the three links of 0.7mm? 1mm? this material is just going to be dremel'd off afterwards...
| Re: Interlocked shapes [message #34231 is a reply to message #34230 ] Tue, 13 September 2011 22:47 UTC |
No, because the only materials that support a 0.7mm wire structure are WSF, FD and FUD.
With the dimensions you give, you'd be looking minimum 2mm for stainless and probably around 1.2mm for silver (I've not got any real experience with silver, but this is my 'educated guess' as the dimensions are really for 3D printed wax that is invested and cast)... you need to start thinking along the lines of material volume and supported material mass - there's no real hard and fast answer unless someone has done it already.
| Re: Interlocked shapes [message #34235 is a reply to message #6482 ] Wed, 14 September 2011 00:55 UTC |
I'd say no with silver, even with sprues.
