Home » Community » 3D modeler needed » 3D car modeler needed
3D car modeler needed [message #64534] Thu, 21 March 2013 01:18 UTC Go to next message
avatar Themikepeng  is currently offline Themikepeng
I have been wanting to get a scale model of a 1987-1991 Toyota Camry for a couple of years, but there were none at all. Now there is finally a 3D printing community, so I was hoping I could finally get one. It would be best in 1:64 or 1:87 scale and shell only. This might help:
http://sketchup.google.com/3dwarehouse/details?mid=ea6f031ad 4438f87166390f4a0367453&prevstart=0
Thank you very much
[Updated on: Thu, 21 March 2013 01:21 UTC]
Re: 3D car modeler needed [message #64563 is a reply to message #64534 ] Thu, 21 March 2013 08:03 UTC Go to previous messageGo to next message
avatar ComesToLife  is currently offline ComesToLife
I make very detailed car models for other industries such as games and video productions so modeling a vehicle is not an issue, but there seem to be a finished model already in the link you had provided. is there something wrong with that one that you are hiring another 3D modeler to make another model?
Custom 3D Artist
www.ComesToLife.com
Re: 3D car modeler needed [message #64569 is a reply to message #64534 ] Thu, 21 March 2013 12:20 UTC Go to previous messageGo to next message
Hi
I can help you with this project. If you have model but is not printable i can adjust it for you or make model from scratch. price for modeling depends on how complex model it is.
Marián
Only limit is your imagination. http://www.shapeways.com/forum/index.php?t=msg&th=13879&start=0&
Re: 3D car modeler needed [message #64587 is a reply to message #64569 ] Thu, 21 March 2013 14:40 UTC Go to previous messageGo to next message
I only need the model in the link modified so it can be 3d printed.
Re: 3D car modeler needed [message #64626 is a reply to message #64587 ] Thu, 21 March 2013 21:32 UTC Go to previous messageGo to next message
avatar V1c3r0y  is currently offline V1c3r0y
PM sent
Re: 3D car modeler needed [message #64631 is a reply to message #64626 ] Thu, 21 March 2013 22:05 UTC Go to previous message
I don't know that you're going to be very happy with the model "as is".
Take a close look at the faceting on this image of the model.
index.php?t=getfile&id=29474&private=0
That level of faceting is really going to show up at 1:87 and even worse at 1:64. It wouldn't be too bad at 1:220, but those facets are really going to show at bigger scales.
To look good, you are either going to have to do a LOT of sanding on the final model, or you are going to have to do a LOT of smoothing on the digital model before you try to print it. It can be done, but it's going to require quite a bit of work.
The other small issue is that you need to be careful when directly copying something off of 3dWarehouse .. do you have the rights to start printing copies? The model you linked to is a modified copy of someone else's original work. You will need to verify whether the original designer surrendered his rights to the model.
  • Attachment: Camry.jpg
    (Size: 159.60KB, Downloaded 76 time(s))
[Updated on: Thu, 21 March 2013 22:08 UTC]
Previous Topic:3D Modeler needed for collaboration
Next Topic:Someone to help create parts for bicycle project
