Home » Support » Bug Reporting » X3D/VRML Color & Textures
X3D/VRML Color & Textures [message #64354] Mon, 18 March 2013 18:15 UTC Go to next message
avatar ttoinou  is currently offline ttoinou
Hi all.
When I upload a X3D file with colored triangles the preview image is monochrome.
Are the preview images & the 3d viewer in color now or not ?
Sorry for not answering on " http://feedback.shapeways.com/forums/111989-shapeways-feedba ck/suggestions/2421281-color-3d-viewer" but it doesn't work !
EDIT :
The only thing I'm able to upload in color is in X3D a set of IndexedTriangleSet !
However this doesn't work when I replace the color attribute with a texture..
Triangulated objects with TriangleSet don't work, and primitives like spheres and cylinders are always monochrome !
Thanks in advance.
Antoine.
[Updated on: Sun, 24 March 2013 20:53 UTC]
Re: Color Preview [message #64355 is a reply to message #64354 ] Mon, 18 March 2013 18:31 UTC Go to previous messageGo to next message
Do you mean vertex coloring?
I remember having troubel with vertex colors using x3d.
VRML worked better when I tried.
Stijn
Re: Color Preview [message #64356 is a reply to message #64355 ] Mon, 18 March 2013 18:38 UTC Go to previous messageGo to next message
To each vertex of each triangle is associated a color.
I thought that the inside of each triangle was colored thanks to a barycentric combination of the three colors... Maybe Shapeways does not support that ?
My code looks like this
<Shape>
<TriangleSet solid='false' ccw='true' colorPerVertex='true' normalPerVertex='true' containerField='geometry'>
<Coordinate point='0.957427144050598 -0.1507 [....] '/>
<Color color='0 [......] '/>
</TriangleSet>
</Shape>
Here is the object made public and downloadable : http://www.shapeways.com/model/981967/color-tetrahedron.html
[Updated on: Tue, 19 March 2013 12:56 UTC]
Re: Color Preview [message #64357 is a reply to message #64356 ] Mon, 18 March 2013 18:41 UTC Go to previous messageGo to next message
Yes that is vertex coloring Smile
Can you try vrml?
Re: Color Preview [message #64358 is a reply to message #64357 ] Mon, 18 March 2013 18:43 UTC Go to previous messageGo to next message
Okay I didn't know that Razz .
The thing is that I'm trying to create a software that produce X3D or VRML file in order to create a colored fractal.
But I'll try to learn it if I have to Smile !
Re: Color Preview [message #64359 is a reply to message #64358 ] Mon, 18 March 2013 18:50 UTC Go to previous messageGo to next message
Well, I think this may be a bug, I figured it was my own files that gave the trouble.
You can use free Meshlab to convert the models to test quickly if vrml will work.
And vrml is a dead simple format, should be fun to learn Wink
Btw, welome to the "club" Wink
3d color fractals are fun!
Re: Color Preview [message #64362 is a reply to message #64359 ] Mon, 18 March 2013 19:47 UTC Go to previous messageGo to next message
Meshlab does not support colors..
I like your Julia vase !
I've tried in VRML :
Shape {
	appearance Appearance {
		material Material { }
		texture ImageTexture {
			url "Untitled.png"
	geometry Cylinder {
      radius 1.3
      height 80.0
It does not work !
Here is the link to the object made public : http://www.shapeways.com/model/982445/vs-2012-essai-vrml.htm l .
[Updated on: Mon, 18 March 2013 20:48 UTC]
Re: Color Preview [message #64363 is a reply to message #64362 ] Mon, 18 March 2013 19:54 UTC Go to previous messageGo to next message
Are you sure you have the latest? Meshlab supports colors just fine!
My vrml is a bit rusty, so unsure whether you example is correct.
Re: Color Preview [message #64412 is a reply to message #64363 ] Tue, 19 March 2013 09:33 UTC Go to previous messageGo to next message
ttoinou: the vrml seems corret. Work in my vrml browser.
Maybe its a good idea to add at the start of the vrml.
Quote:
#VRML V2.0 utf8
But it is not a tesselatet Objekt. Not sure if shapeways support untesseletet vrml objects.
Sorry, you don't have permission to perform this action. ?
[Updated on: Tue, 19 March 2013 09:36 UTC]
Re: Color Preview [message #64422 is a reply to message #64412 ] Tue, 19 March 2013 12:22 UTC Go to previous messageGo to next message
Sorry the cylinder is now public.
What is your VRML Viewer ? I have freeWRL but you can't move the object..
Re: Color Preview [message #64426 is a reply to message #64422 ] Tue, 19 March 2013 12:37 UTC Go to previous messageGo to next message
ok now with texture it is also colored Smile
I Use the VR/AR-Framework .instantreality (http://www.instantreality.org/)
But I have a Idee where the Problem can be:
The Obejct is describe parametric and not teselated. So ther are no texture Coordinates (UW-Map) explicit declared. And it seems the shapeway engine do not generate texture coordinates for parametrcic object. Why shuold it? Normaly all objects are discribed triangulated.
Re: Color Preview [message #64427 is a reply to message #64426 ] Tue, 19 March 2013 13:02 UTC Go to previous messageGo to next message
I thought SW accepted WRL.. They should communicate about what they really accept.
I'll look into this texture coordinates thing.
That doesn't explain the first issue : Color Tetrahedron .
I've also tried a textured cylinder in X3D (it doesn't work) :
    <Shape>
      <Appearance>
        <Material/>
        <ImageTexture url='"Untitled.png" '/>
      </Appearance>
      <Cylinder radius="1.0" height="80.0">
      </Cylinder>
    </Shape>
[Updated on: Tue, 19 March 2013 18:37 UTC]
Re: Color Preview [message #64721 is a reply to message #64427 ] Sat, 23 March 2013 17:26 UTC Go to previous messageGo to next message
I've succeeded in uploading colored triangles in X3D with IndexedTriangleSet. I don't understand why it works with IndexedTriangleSet and not with TriangleSet...
But if I upload the same model where I put a texture instead of colors SW doesn't accept it ! (still in X3D, maybe that could work in VRML)
[Updated on: Sun, 24 March 2013 09:12 UTC]
Re: Color Preview [message #65006 is a reply to message #64721 ] Wed, 27 March 2013 18:17 UTC Go to previous messageGo to next message
I tried a textured IndexedFaceSet in VRML and Shapeways does not accept it (it is not precised why).
It opens well in Meshlab and with Instant Player (with textures of course).
I really don't see what i'm doing wrong!
NavigationInfo {
  type [ "EXAMINE", "ANY" ]
Background {
skyColor [ 1 1 1 ]
Transform {
  scale 1 1 1
  translation 0 0 0
  children
Shape
texture ImageTexture { url "TEXTURE.png" }
material Material {
ambientIntensity 0.2
specularColor 0.1 0.1 0.1
shininess .5
geometry IndexedFaceSet
creaseAngle .5
solid TRUE
coord Coordinate
point
1.14891254901886 -0.180906772613525 48.6943778991699,-0.57445627450943 -0.795805394649506 49.6802253723145,-21.9450969696045 -40.180908203125 -16.6253528594971,-21.9450969696045 -40.180908203125 -16.6253528594971,-0.57445627450943 -0.795805394649506 49.6802253723145,-23.6684665679932 -40.7958068847656 -15.6395034790039,-0.57445627450943 -0.795805394649506 49.6802253723145,-0.57445627450943 0.976712167263031 48.594783782959,-23.6684665679932 -40.7958068847656 -15.6395034790039,-23.6684665679932 -40.7958068847656 -15.6395034790039,-0.57445627450943 0.976712167263031 48.594783782959,-23.6684665679932 -39.0232887268066 -16.7249431610107,-0.57445627450943 0.976712167263031 48.594783782959,1.14891254901886 -0.180906772613525 48.6943778991699,-23.6684665679932 -39.0232887268066 -16.7249431610107,-23.6684665679932 -39.0232887268066 -16.7249431610107,1.14891254901886 -0.180906772613525 48.6943778991699,-21.9450969696045 -40.180908203125 -16.6253528594971,1.16819250583649 0.143330127000809 49.2238540649414,-0.324288666248322 -0.389187723398209 50.0776214599609,1.14891254901886 -0.180906772613525 48.6943778991699,1.14891254901886 -0.180906772613525 48.6943778991699,-0.324288666248322 -0.389187723398209 50.0776214599609,-0.57445627450943 -0.795805394649506 49.6802253723145,-0.324288666248322 -0.389187723398209 50.0776214599609,-0.324288666248322 1.14585757255554 49.1376037597656,-0.57445627450943 -0.795805394649506 49.6802253723145,-0.57445627450943 -0.795805394649506 49.6802253723145,-0.324288666248322 1.14585757255554 49.1376037597656,-0.57445627450943 0.976712167263031 48.594783782959,-0.324288666248322 1.14585757255554 49.1376037597656,1.16819250583649 0.143330127000809 49.2238540649414,-0.57445627450943 0.976712167263031 48.594783782959,-0.57445627450943 0.976712167263031 48.594783782959,1.16819250583649 0.143330127000809 49.2238540649414,1.14891254901886 -0.180906772613525 48.6943778991699,0.346410125494003 0.599999964237213 49.9695930480957,0.346410125494003 0.599999964237213 49.9695930480957,1.16819250583649 0.143330127000809 49.2238540649414,1.16819250583649 0.143330127000809 49.2238540649414,0.346410125494003 0.599999964237213 49.9695930480957,-0.324288666248322 -0.389187723398209 50.0776214599609,0.346410125494003 0.599999964237213 49.9695930480957,0.346410125494003 0.599999964237213 49.9695930480957,-0.324288666248322 -0.389187723398209 50.0776214599609,-0.324288666248322 -0.389187723398209 50.0776214599609,0.346410125494003 0.599999964237213 49.9695930480957,-0.324288666248322 1.14585757255554 49.1376037597656,0.346410125494003 0.599999964237213 49.9695930480957,0.346410125494003 0.599999964237213 49.9695930480957,-0.324288666248322 1.14585757255554 49.1376037597656,-0.324288666248322 1.14585757255554 49.1376037597656,0.346410125494003 0.599999964237213 49.9695930480957,1.16819250583649 0.143330127000809 49.2238540649414,-21.9450969696045 -40.180908203125 -16.6253528594971,-23.6684665679932 -40.7958068847656 -15.6395034790039,-22.2722263336182 -40.456672668457 -17.0756721496582,-22.2722263336182 -40.456672668457 -17.0756721496582,-23.6684665679932 -40.7958068847656 -15.6395034790039,-23.7647094726563 -40.9891891479492 -16.2219009399414,-23.6684665679932 -40.7958068847656 -15.6395034790039,-23.6684665679932 -39.0232887268066 -16.7249431610107,-23.7647094726563 -40.9891891479492 -16.2219009399414,-23.7647094726563 -40.9891891479492 -16.2219009399414,-23.6684665679932 -39.0232887268066 -16.7249431610107,-23.7647094726563 -39.4541435241699 -17.1619205474854,-23.6684665679932 -39.0232887268066 -16.7249431610107,-21.9450969696045 -40.180908203125 -16.6253528594971,-23.7647094726563 -39.4541435241699 -17.1619205474854,-23.7647094726563 -39.4541435241699 -17.1619205474854,-21.9450969696045 -40.180908203125 -16.6253528594971,-22.2722263336182 -40.456672668457 -17.0756721496582,-22.2722263336182 -40.456672668457 -17.0756721496582,-23.7647094726563 -40.9891891479492 -16.2219009399414,-23.4404201507568 -40.5999984741211 -17.3097286224365,-23.4404201507568 -40.5999984741211 -17.3097286224365,-23.7647094726563 -40.9891891479492 -16.2219009399414,-23.4404201507568 -40.5999984741211 -17.3097286224365,-23.7647094726563 -40.9891891479492 -16.2219009399414,-23.7647094726563 -39.4541435241699 -17.1619205474854,-23.4404201507568 -40.5999984741211 -17.3097286224365,-23.4404201507568 -40.5999984741211 -17.3097286224365,-23.7647094726563 -39.4541435241699 -17.1619205474854,-23.4404201507568 -40.5999984741211 -17.3097286224365,-23.7647094726563 -39.4541435241699 -17.1619205474854,-22.2722263336182 -40.456672668457 -17.0756721496582,-23.4404201507568 -40.5999984741211 -17.3097286224365,-23.4404201507568 -40.5999984741211 -17.3097286224365,-22.2722263336182 -40.456672668457 -17.0756721496582,-23.4404201507568 -40.5999984741211 -17.3097286224365]
coordIndex
0 1 2 -1
3 4 5 -1
6 7 8 -1
9 10 11 -1
12 13 14 -1
15 16 17 -1
18 19 20 -1
21 22 23 -1
24 25 26 -1
27 28 29 -1
30 31 32 -1
33 34 35 -1
36 37 38 -1
39 40 41 -1
42 43 44 -1
45 46 47 -1
48 49 50 -1
51 52 53 -1
54 55 56 -1
57 58 59 -1
60 61 62 -1
63 64 65 -1
66 67 68 -1
69 70 71 -1
72 73 74 -1
75 76 77 -1
78 79 80 -1
81 82 83 -1
84 85 86 -1
87 88 89 -1 ]
texCoord TextureCoordinate
point
0 0, 1 0, 0 1, 1 1
texCoordIndex [
0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1,0 1 2 -1, 2 1 3 -1]
Re: Color Preview [message #65016 is a reply to message #65006 ] Wed, 27 March 2013 19:04 UTC Go to previous messageGo to next message
In your posting above, you're missing this header line from the top of the file:
#VRML V2.0 utf8
Then, are you uploading a ZIP that includes no folders, and includes the file TEXTURE.png ??
That file name is case sensitive, etc.
Re: Color Preview [message #65021 is a reply to message #65006 ] Wed, 27 March 2013 19:21 UTC Go to previous messageGo to next message
As I understand, VRML is a 'markup language' intended for online browser viewing, not all functions may work the same with Shapeways for a model upload - basically if it works and looks good with Accutrans3D, it should work with Shapeways (Meshlab can be temperamental with colour models, might show ok, but messes up the save)
Ah, just remembered why - Meshlab messes up the save because it can cope with overlapping colour geometry, whereas Shapeways does not.
Re: Color Preview [message #65075 is a reply to message #65021 ] Thu, 28 March 2013 18:42 UTC Go to previous message
It worked !
Sorry I should have re read the whole thread before complaining...
Thanks to all of you Smile .
(but there's a lot of things that still don't work.. anyway I'll stick with VRML & IndexedFaceSet)
[Updated on: Thu, 28 March 2013 18:47 UTC]
Previous Topic:3d image preview
Next Topic:Paypal orders keep falling through the cracks
