| need a file made [message #63897] Tue, 12 March 2013 16:50 UTC |
Hi
I need to create a charm from a picture.
Its simple basic shapes~ Quilt Blocks.
Thank You,
Nicole
Attachment: label#4.PDF
(Size: 11.71MB, Downloaded 66 time(s))
| Re: need a file made [message #63898 is a reply to message #63897 ] Tue, 12 March 2013 17:00 UTC |
| nmadeux13 wrote on Tue, 12 March 2013 16:50 | Hi
Thank You,
Nicole
| Re: need a file made [message #64147 is a reply to message #63897 ] Fri, 15 March 2013 11:38 UTC |
I've moved this thread to the '3D Modeler Needed' forum.
| Re: need a file made [message #64298 is a reply to message #64147 ] Sun, 17 March 2013 19:30 UTC |
What size did you want them? Did you want them to look 'quilted'?
This test model is 3/8" - 9.525mm square, 1.5mm thick. with a 3.5mm eyelet
http://skfb.ly/5kj3fb
[Updated on: Sun, 17 March 2013 19:38 UTC] jacantdesign@gmail.com
| Re: need a file made [message #64300 is a reply to message #64298 ] Sun, 17 March 2013 20:38 UTC |
Hi
Your daisy charm is exactly wat I am looking for
In several different quilt block styles
Wat material is that made from ?
| Re: need a file made [message #64445 is a reply to message #63897 ] Tue, 19 March 2013 20:07 UTC |
No Message Body
[Updated on: Tue, 19 March 2013 20:53 UTC] jacantdesign@gmail.com
| Re: need a file made [message #64478 is a reply to message #64445 ] Wed, 20 March 2013 14:08 UTC |
hi
the ones i have are approx
12mm widex15mm high
would you like me to send you a file with several different types of quilt blocks?
split rail
ohio star
fox and geese
card trick
log cabin
pin wheel
these are names of just a few:)
thank you
nicole
| Re: need a file made [message #64479 is a reply to message #64301 ] Wed, 20 March 2013 14:22 UTC |
on the 508 i cannot get that program to open on my
computer
| Re: need a file made [message #64490 is a reply to message #64479 ] Wed, 20 March 2013 16:06 UTC |
Sure, send the file by PM
Do you want me to scale the 507 and 508 to15mm x 12mm? How thick do you want them? 3mm?
Here is the 508. The corners are rounded because you get what are known as 'degenerated faces and edges'
Attachment: 508.png
(Size: 81.18KB, Downloaded 110 time(s))
[Updated on: Wed, 20 March 2013 16:09 UTC] jacantdesign@gmail.com
| Re: need a file made [message #64494 is a reply to message #64490 ] Wed, 20 March 2013 16:27 UTC |
can you send me the 507 as the same file type so i can open it?
Have a couple of questions on getting a large qty?
In an earlier conversation with another person here they said i might b able
to have a large amount made and then I could finish them? Like a jeweler
would do? If I was interested in that what would be the prices?
thank you
nicole
| Re: need a file made [message #64495 is a reply to message #64490 ] Wed, 20 March 2013 16:35 UTC |
these are kind of detailed
you can just use them as an idea.
thank you
Nicole
| Re: need a file made [message #64496 is a reply to message #64490 ] Wed, 20 March 2013 16:53 UTC |
a few more samples for ideas:)
thanks
nicole
| Re: need a file made [message #64498 is a reply to message #64490 ] Wed, 20 March 2013 16:59 UTC |
This is awesome!!
yes 3mm thick would b perfect.
and some where around 12mmx15mm would b great
thank you
