need a file made
Discussion in '3D Design Requests' started by 324768_deleted, Mar 12, 2013.
  1. Hi
    I need to create a charm from a picture.
    Its simple basic shapes~ Quilt Blocks.
    Thank You,
    Nicole
  2.
  3. bartv
    bartv Member
    I've moved this thread to the '3D Modeler Needed' forum.
  4. JACANT
    JACANT Well-Known Member
    What size did you want them? Did you want them to look 'quilted'?
    This test model is 3/8" - 9.525mm square, 1.5mm thick. with a 3.5mm eyelet
    http://skfb.ly/5kj3fb
  5. Hi
    Your daisy charm is exactly wat I am looking for
    In several different quilt block styles
    Wat material is that made from ?
  6. JACANT
  7. JACANT
  8. hi
    the ones i have are approx
    12mm widex15mm high
    would you like me to send you a file with several different types of quilt blocks?
    split rail
    ohio star
    fox and geese
    card trick
    log cabin
    pin wheel
    these are names of just a few:)
    thank you
    nicole
  9. on the 508 i cannot get that program to open on my
    computer
  10. JACANT
    Sure, send the file by PM
    Do you want me to scale the 507 and 508 to15mm x 12mm? How thick do you want them? 3mm?
    Here is the 508. The corners are rounded because you get what are known as 'degenerated faces and edges'
  11. can you send me the 507 as the same file type so i can open it?
    Have a couple of questions on getting a large qty?
    In an earlier conversation with another person here they said i might b able
    to have a large amount made and then I could finish them? Like a jeweler
    would do? If I was interested in that what would be the prices?
    thank you
    nicole
  12. these are kind of detailed
    you can just use them as an idea.
    thank you
    Nicole
  13. a few more samples for ideas:)
    thanks
    nicole
  14. This is awesome!!
    yes 3mm thick would b perfect.
    and some where around 12mmx15mm would b great
    thank you :)
