What size did you want them? Did you want them to look 'quilted'? This test model is 3/8" - 9.525mm square, 1.5mm thick. with a 3.5mm eyelet http://skfb.ly/5kj3fb
Hi Your daisy charm is exactly wat I am looking for In several different quilt block styles Wat material is that made from ?
At the size it is now, it could be any of the 'plastic' materials and silver. https://www.shapeways.com/materials Here's another. My interpretation of '508' Same basic size. https://skfb.ly/5kj3f1dcba
hi the ones i have are approx 12mm widex15mm high would you like me to send you a file with several different types of quilt blocks? split rail ohio star fox and geese card trick log cabin pin wheel these are names of just a few thank you nicole
Sure, send the file by PM Do you want me to scale the 507 and 508 to15mm x 12mm? How thick do you want them? 3mm? Here is the 508. The corners are rounded because you get what are known as 'degenerated faces and edges'
can you send me the 507 as the same file type so i can open it? Have a couple of questions on getting a large qty? In an earlier conversation with another person here they said i might b able to have a large amount made and then I could finish them? Like a jeweler would do? If I was interested in that what would be the prices? thank you nicole
This is awesome!! yes 3mm thick would b perfect. and some where around 12mmx15mm would b great thank you
