The Cleaning Process
The Cleaning Process [message #63851] Tue, 12 March 2013 06:25 UTC Go to next message
avatar thomaswood  is currently offline thomaswood
I have recently had a my first few creations fail because of insufficient escape holes and and inability to clean. Can anyone shed any light on the cleaning process so I can make the relevant changes?
some more detail:
One of my models is a standing low poly wolf and he has 4 legs each around 4mm in diameter. Is a 2mm tunnel up each leg leading to the interior cavity enough to clean out waste material. Each leg is around 60mm long
Re: The Cleaning Process [message #63858 is a reply to message #63851 ] Tue, 12 March 2013 07:34 UTC Go to previous messageGo to next message
There's a video here that shows the print and cleaning process. Basically an operator needs to be able to blow the support powder out using an air jet.
2mm tubes up the legs of your wolf should be ouk, but you may find some support material still in the model depending on how diligent the cleaning operator is.
Re: The Cleaning Process [message #63859 is a reply to message #63858 ] Tue, 12 March 2013 07:39 UTC Go to previous messageGo to next message
Thanks for the link.
That has answered my question perfectly.
Fingers crossed my new versions make the grade.
Thank you for the rapid response.
Re: The Cleaning Process [message #63908 is a reply to message #63859 ] Tue, 12 March 2013 17:30 UTC Go to previous messageGo to next message
avatar NickHawkins  is currently offline NickHawkins
I've recently had a (1/200 scale aircraft) model in WSF rejected for the same reason, the same model had been printed without comment before.
Having watched the video I can't believe that models are now being rejected because Shapeways can't recover the unfused powder from the inside of a small model. It was clear that much more powder was blown around the workshop (and not into the collectors) during the rough cleaning process than could be recovered from the inside of a small model.
Can anyone confirm if Shapeways are now enforcing the cleaning hole requirement for small WSF models to the letter?
If so I will need to redesign several models to avoid disappointment for future customers (as I suspect many other designs will).
Re: The Cleaning Process [message #63915 is a reply to message #63851 ] Tue, 12 March 2013 18:59 UTC Go to previous messageGo to next message
Unfortunately, for some rules, it's up to the reviewers discretion. Cleaning is less for reclaiming material, and more so we aren't shipping powdery models to customers.
Re: The Cleaning Process [message #63921 is a reply to message #63915 ] Tue, 12 March 2013 19:36 UTC Go to previous messageGo to next message
Youknowwho4eva wrote on Tue, 12 March 2013 18:59
Thanks for the clarification.
Sadly that means as a designer I have to allow for "worst case" reviewers, it seems to be a rather stochastic process.
From my current experience of WSF it seems that anything trapped inside after shipping normally stays there unless you drill holes in the model (EG for mounting on a flight stand). Once painted there's normally no way anymore powder can get out.
Re: The Cleaning Process [message #63922 is a reply to message #63851 ] Tue, 12 March 2013 19:46 UTC Go to previous messageGo to next message
A solution for variations in rejections is in the works.
The problem with the left over powder, isn't so much for people that are expecting the powder. If a customer bought the item expecting a final product, and powder come out, there is a chance they wouldn't be happy, and could reflect negatively in there future shopping choices.
Re: The Cleaning Process [message #63923 is a reply to message #63922 ] Tue, 12 March 2013 19:53 UTC Go to previous messageGo to next message
My first rejection was because the hole was tiny, just enough to ensure the model was marked as hollow and I suspect was completely sealed by the fusing process. So I made it bigger...
Would it be possible to have a standard for strong flexible that either requires either the large cleanable holes OR a tiny hole that will be sealed by the fusing process? Either way the customer gets a model with no dust (unless they cut it open).
Re: The Cleaning Process [message #63924 is a reply to message #63851 ] Tue, 12 March 2013 20:06 UTC Go to previous messageGo to next message
I know that is an option for FD and FUD. But the support for those materials is not reusable.
Just wondering, how small is your hollow area? Is it needed? I know any amount of material can save money, but it sounds as if your hollow area is very small?
Re: The Cleaning Process [message #63925 is a reply to message #63924 ] Tue, 12 March 2013 20:25 UTC Go to previous message
I'm designing 'toys' for wargamer's rather than precision scale models for collectors, as such there is a 'market expectation' regarding price that I try to meet.
These are also models that may be used on fairly tall flight stands so minimising weight is of practical benefit.
The biggest saving I have achieved is a 14cm3 model that only requires 3.5cm3 of material, this is exceptional. I'd guess that typical savings are 25% to 33%, a useful saving for something that is intended to be ordered in multiples rather than singles and as part of a multi-model order.
Previous Topic:Wire models
Next Topic:After all the iPhone Cases, now a really useful project!
