Home » Community » General Discussion » Help! Full collor sandstone almost $500
Help! Full collor sandstone almost $500 [message #63628] Sat, 09 March 2013 01:19 UTC Go to next message
avatar rubyscooby  is currently offline rubyscooby
I created a full color sandstone model and it's over $400. I created the right size hole and it's about 13 cm wide. This seems like a crazy amount of money? What am I doing wrong. This is my first color sandstone model so far. I double checked on the size as I did see on the tutorials VRML might send it too big.
http://www.shapeways.com/model/964379/candle.html?li=my-mode ls&key=8a1b141a5aa50f211c8df9eb47417a56
Please help
Thanks Ruby
Ruby
Re: Help! Full collor sandstone almost $500 [message #63633 is a reply to message #63628 ] Sat, 09 March 2013 02:41 UTC Go to previous messageGo to next message
I wonder if it's because it's not hollow? I am trying Meshlabs to hollow it out without much luck so far.
Re: Help! Full collor sandstone almost $500 [message #63642 is a reply to message #63633 ] Sat, 09 March 2013 03:53 UTC Go to previous messageGo to next message
If it's not hollow, there's your problem. But, even if you hollowed it out, it'd run about $100.
http://stonysmith.com/wired/VolumeEstimator.asp?L=105&W= 137&H=128&T=3&S=1
Re: Help! Full collor sandstone almost $500 [message #63676 is a reply to message #63642 ] Sat, 09 March 2013 18:23 UTC Go to previous message
Thanks your right! I hollowed it out and it's down to $40! Yea. I hope it passes inspection. For anyone curious on how I hollowed it out. I duplicated the model and then did a negative inflate in Zbrush. I polished it and then did a merge. The hole I cut out using booleans in C4D. Hope it works!
Ruby
Previous Topic:Help wanted with 3D printer selection (details provided)
Next Topic:Questions
