| Walls too thin? [message #6229] Wed, 02 September 2009 11:19 UTC |
Hi there,
I'm still trying to create this double DIN adapter. Since it is much too expensive I'm trying to make it hollow. A file says a thousand words.
I get the following error message:
| Quote: |
We could not determine the size and/or volume of your model due to an invalid model structure. Please investigate the problem and try again.
I guess the walls are too thin. But my software says they are more than 2mm everywhere. I'd absolutely appreciate it if someone could investigate this issue... again.
Hendrik
[Updated on: Wed, 02 September 2009 11:39 UTC]
| Re: Walls too thin? [message #6230 is a reply to message #6229 ] Wed, 02 September 2009 12:31 UTC |
I got that error when I exported a stl in inches and in an attempt of being lazy and just shrinking the file, I selected mm on shapeways. What software are you using?
| Re: Walls too thin? [message #6232 is a reply to message #6231 ] Wed, 02 September 2009 14:19 UTC |
Try it just to see if it works, if it does make it too big just delete it. Then you'll know it is too small
[Updated on: Wed, 02 September 2009 14:20 UTC] The Mad Moder
| Re: Walls too thin? [message #6252 is a reply to message #6229 ] Thu, 03 September 2009 12:41 UTC |
Err, I'm afraid I haven't got it, yet.
Please have a look at the picture I have attached. As you can see the holes in the bottom are open. I've also checked the inside of the holes. There is no face covering the holes.
Attachment: Holes.jpg
(Size: 49.47KB, Downloaded 120 time(s))
| Re: Walls too thin? [message #6254 is a reply to message #6252 ] Thu, 03 September 2009 13:32 UTC |
Here is another picture I've just created with MiniMagics (thanks to Shapeways for this advice). Also, no face covering the holes in the bottom of the object.
| Re: Walls too thin? [message #6326 is a reply to message #6254 ] Sun, 06 September 2009 13:03 UTC |
Hi SeveQ,
I just uploaded your STL file with size unit mm and everything went fine. I also manually checked the model and it's all perfectly manifold, normals oriented fine etc.
So I'm not sure what the problem is?
| Re: Walls too thin? [message #6328 is a reply to message #6229 ] Sun, 06 September 2009 14:39 UTC |
Eh, what? Have you Shapeways people changed something to the checking algorithms? Now it works and I definitely haven't changed anything to the object, just uploaded the same file again. *confused*
| Re: Walls too thin? [message #6364 is a reply to message #6328 ] Tue, 08 September 2009 18:18 UTC |
I checked and I don't believe we did an update after you posted your message. Not sure what caused this..
| Re: Walls too thin? [message #6366 is a reply to message #6229 ] Tue, 08 September 2009 18:30 UTC |
Huh! Weird...
Well then, I'd say, consider this issue solved. Thanks for your help though.
