New to this
New to this [message #62754] Mon, 25 February 2013 11:47 UTC Go to next message
avatar whelpd  is currently offline whelpd
Hi I am new to the whole 3d modelling and using 3Dtin created a part for a toy. I am unsure how to gauge the size of the product and am on a budget. If any one can help it would be great.
the 3dtin model - http://www.3dtin.com/ymwe
p.s. when importing I selected millimeters. If this helps
Re: New to this [message #62769 is a reply to message #62754 ] Mon, 25 February 2013 19:26 UTC Go to previous messageGo to next message
Download your file as STL.
Get a copy of http://www.netfabb.com/basic.php
You can measure, repair, rotate and scale your file here.
Read the Design Rules for each material.
Shapeways does not usually allow multiple parts in a file except for earrings and a pair or set of something. You will have to join your parts together with 'sprues' or make a 'cage' around them.
index.php?t=getfile&id=28012&private=0
  • Attachment: whelpd.png
    (Size: 101.02KB, Downloaded 167 time(s))
Re: New to this [message #62811 is a reply to message #62769 ] Tue, 26 February 2013 10:04 UTC Go to previous message
That's only for Silver and Steal.
You can use multiple Parts to a file if the parts are big enough. Small small parts must sprued together, or they will go through the drain by the cleaning process Wink
To Check the cost and the automatic checks I sometimes upload a in between model. Than you can se if something is totally wrong and you can see in the price category.
Previous Topic:Crescent Moon Pendant
Next Topic:Ginosaji (The SpoonKiller)
