| Light permeable [message #6112] Fri, 28 August 2009 14:20 UTC |
Currently I'm creating a small cube which will house a small LED or bulb. There is a small cut-out which will let the light escape, which will be covered by a thin piece of film (http://i28.tinypic.com/34dpues.jpg) - it's a little soppy but what the hell!
My question is: Do the materials have varying levels of translucency? The last thing I want is for all the light to escape out of the material!
If worst comes to worst, is there anything I could line my housing with?
Any help would be much appreciated,
Quinton
| Re: Light permeable [message #6114 is a reply to message #6112 ] Fri, 28 August 2009 15:54 UTC |
The base material WSF (White, Strong, and Flexable) will easily let light escape. It's quite translucent. But a little paint can easily cure that.
| Re: Light permeable [message #6120 is a reply to message #6112 ] Fri, 28 August 2009 18:28 UTC |
Thanks WiKKiDWidgets for a quick response!
I was afraid that'd be the issue. So you're suggesting a quick lick of black paint on the inside, or perhaps coating it all?
Quinton
| Re: Light permeable [message #6123 is a reply to message #6120 ] Fri, 28 August 2009 19:55 UTC |
Depending on your application, either will suffice. Albeit, I'd steer you towards painting it all as WSF has a very permeable surface and might let some paint bleed through if not sufficiently thick enough.
| Re: Light permeable [message #6163 is a reply to message #6123 ] Sun, 30 August 2009 04:45 UTC |
It won't soak in if you use a spray putty or primer first.
Every part I paint gets some 3 coats of spray putty and 1 coat of primer, rubbed back inbetween coats, before paint even touches it.
That said, light won't escape at all if your wall sections are 5mm+
