Home » Support » 3D Design » Wall too thin
Wall too thin [message #61027] Tue, 29 January 2013 19:47 UTC Go to next message
avatar WoodCarving  is currently offline WoodCarving
I've designed a project with Gimp (2D) and I used the Create -> 2D to 3D but walls are too thin.
I tried to designed my model with blender.
But i'm a beginner and i'm not sure that my walls are in the good size..
How can i make my models printable ?
[Updated on: Wed, 20 February 2013 17:22 UTC]
Re: Wall too thin [message #61030 is a reply to message #61027 ] Tue, 29 January 2013 20:21 UTC Go to previous messageGo to next message
the min wall thickness needs to be at least7.62 mm(.3") according to the picture. You know that Blender can import a svg that you create from gimp as a curve,turn it into a filled and extruded mesh. If you want to use the co-creator, try scaling the bw image up, then try uploading. or if you want, post the bw image here. that model should take me just a few minutes.Add the base dimension measurements you want it printed at, material choice and height of the font.The stuff you input into the c0-creator
[Updated on: Tue, 29 January 2013 20:24 UTC]
Re: Wall too thin [message #61038 is a reply to message #61030 ] Tue, 29 January 2013 22:42 UTC Go to previous messageGo to next message
Fredd wrote on Tue, 29 January 2013 20:21
Fred.. you're off by ten. That is .03" or 0.7mm for WSF
Re: Wall too thin [message #61052 is a reply to message #61027 ] Wed, 30 January 2013 02:05 UTC Go to previous messageGo to next message
Gaah I need glasses. big difference between .03" and 3". either that or the beer was typing.Sad.I am betting it was the beer.) and .3"
*Hobbles back to his room at "The Home."*
[Updated on: Wed, 30 January 2013 02:06 UTC]
Re: Wall too thin [message #61122 is a reply to message #61030 ] Thu, 31 January 2013 17:36 UTC Go to previous messageGo to next message
Thank you for the answers.
Here's the model i designed with Blender.
[Updated on: Wed, 20 February 2013 17:23 UTC]
Re: Wall too thin [message #61124 is a reply to message #61027 ] Thu, 31 January 2013 18:09 UTC Go to previous messageGo to next message
Woodcarving, please attach the image you uploaded for the 2D 3D creator, and what material you'd like it printed in. That way people that can help you get it printed know exactly what to do.
Re: Wall too thin [message #61125 is a reply to message #61124 ] Thu, 31 January 2013 18:26 UTC Go to previous messageGo to next message
Ok, I'm sorry I'm french I've some difficulties with English.
I'll do it.
Re: Wall too thin [message #61126 is a reply to message #61125 ] Thu, 31 January 2013 18:37 UTC Go to previous messageGo to next message
Here's the picture I used for the 2D 3D creator.
I would like in stainless steel.
Re: Wall too thin [message #61127 is a reply to message #61126 ] Thu, 31 January 2013 18:38 UTC Go to previous messageGo to next message
Here's a preview of the final model I want.
Re: Wall too thin [message #61161 is a reply to message #61027 ] Fri, 01 February 2013 07:16 UTC Go to previous messageGo to next message
If you are going to use creator, try scaling the image by 3. Your Model had the dimensions of about 2mmx2mmx 6mm when I opened The import as a either a svg or a dxf it was way tiny, when path was converted to a curve.Still needs converted to a mesh before export also. But you cleaned up the vector import very well, I might add.
Re: Wall too thin [message #62477 is a reply to message #61027 ] Wed, 20 February 2013 17:24 UTC Go to previous message
I fanally succes to make it printable by using Inkscape.
Thank you for yor answers that help me
Previous Topic:3D ceramics printing and handcraft painting
Next Topic:How do I get my Radius round not steped?
