| Modeler needed for adjustments to an OBJ file [message #60784] Fri, 25 January 2013 18:49 UTC |
Hi everyone,
I need some adjustments to the wall thickness in a piece of jewelry that I am trying to print. It printed once and was rejected once, so I think the adjustments would be fairly minor. Please get in touch if you are interested and I'll explain more.
Nathan
| Re: Modeler needed for adjustments to an OBJ file [message #60807 is a reply to message #60784 ] Fri, 25 January 2013 22:18 UTC |
Just curious as to why it was rejected? and why it would have printed one time already
Tj Solo
| Re: Modeler needed for adjustments to an OBJ file [message #60808 is a reply to message #60807 ] Fri, 25 January 2013 22:23 UTC |
Apparently it is on the border of being dangerously too thin...the first time it slipped through the inspection process and printed ok, the second time it was caught. As shapeways explained, even though it might be possible to print as is, when they are running multiple models at once, they need to minimize the possibility of one model within the run failing.
| Re: Modeler needed for adjustments to an OBJ file [message #60812 is a reply to message #60808 ] Fri, 25 January 2013 23:45 UTC |
Ohh OK guess that makes since. Where you able to get it fixed?
Tj Solo
| Re: Modeler needed for adjustments to an OBJ file [message #60964 is a reply to message #60812 ] Mon, 28 January 2013 16:40 UTC |
I was able to, thanks TJ
| Re: Modeler needed for adjustments to an OBJ file [message #60965 is a reply to message #60964 ] Mon, 28 January 2013 16:42 UTC |
No problem
Tj Solo
