Tap and Drill guide
 () 3 Vote(s)
Tap and Drill guide [message #5848] Thu, 13 August 2009 17:24 UTC
Ever been making a model and needed to make a hole for a screw to fit into? Wondering just how big that hole is supposed to be? Well the attached document should answer that for you!!
Document is in PDF format and is printable.
Usage:
Find the screw that you want to use in the left column and then find the proper hole size in decimal inches and millimeters in the last two columns. The guide also lists the exact drill to use as well.
Hope this helps!!
WiKKiD
Previous Topic:Hard/Smooth edges ?
Next Topic:Taboo, to make my own "ring poem"
