| Re: Mold-making/Resin-casting with a Shapeways model... [message #60259 is a reply to message #60252 ] Tue, 15 January 2013 14:21 UTC |
Simply put, WSF is nothing more than Nylon. I might be totally off base, but I can't imagine that the 'rubber chemicals' will do any damage at all to the nylon, especially given that you're going to be coating the nylon with the release agent.
If you want to test it, go find a nylon coat hanger and try casting a section of it.
The one thing you need to consider is that the printing process produces a porus matrix, rather than solid. It will suck up quite a bit of the release agent, but that shouldn't hurt what you're trying to accomplish.
| Re: Mold-making/Resin-casting with a Shapeways model... [message #60387 is a reply to message #60262 ] Fri, 18 January 2013 10:10 UTC |
i have been making moulds of models since 1985 and have moulded all sorts of things.
i have now started to mould 3d printed models as well in the white nylon.
it will be ok in a silicone mould as there is no presure but thin pieces may break off when demoulding it.
i have also vulcanised some white nylon in a vulcaniser as 90 degc and 10 tons of presure but these were solid parts and it had no detrimental effect at all.
you will not be able to sand down the 3d print to make it smooth however esp in areas of detail.
i make a mould then a cast and then modify that cast instead, costs more in moulds but it is worth it in the end.
good luck with it, it is a steep learning curve.
[Updated on: Fri, 18 January 2013 10:11 UTC]
| Re: Mold-making/Resin-casting with a Shapeways model... [message #60389 is a reply to message #60388 ] Fri, 18 January 2013 12:49 UTC |
good luck with ti, if you need any advice on moulding ect please email me
sales@sandsmodels.com
see my stuff on
www.sandsmodels.com
thanks
shaun
