Home » Support » 3D Printing » High output STL detail
High output STL detail [message #60198] Mon, 14 January 2013 17:00 UTC Go to next message
avatar Esoteric777  is currently offline Esoteric777
I feel like im stymieing myself ive seen some great models on this site but when i do them they some come out with a really stepped edge. this is my current STL export setting it could be improved but i dont know where to start.
http://i.imgur.com/7d5YX.jpg
Re: High output STL detail [message #60200 is a reply to message #60198 ] Mon, 14 January 2013 18:22 UTC Go to previous messageGo to next message
What program is that?
Re: High output STL detail [message #60208 is a reply to message #60200 ] Mon, 14 January 2013 19:56 UTC Go to previous messageGo to next message
Looking at the models in your shop, there is nothing wrong with the settings you have now.
By 'stepping' do you mean when they have been printed?
WSF prints with stepped lines depending on the geometry of your model.
Check this link http://www.shapeways.com/materials/strong-flexible-design-gu idelines Print lines or "Stepping"
jacantdesign@gmail.com
Re: High output STL detail [message #60242 is a reply to message #60200 ] Tue, 15 January 2013 05:22 UTC Go to previous messageGo to next message
sorry the program is autodesk inventor 2013 student edition
Re: High output STL detail [message #60243 is a reply to message #60208 ] Tue, 15 January 2013 05:23 UTC Go to previous messageGo to next message
JACANT wrote on Mon, 14 January 2013 19:56
thanks, i mostly get FUD parts but last time i had stuff made it had a step to it on a curved surface
Re: High output STL detail [message #60286 is a reply to message #60208 ] Wed, 16 January 2013 07:43 UTC Go to previous messageGo to next message
I had it happen with FUD, at that setting it only gave it 13k poly count
http://i.imgur.com/ID7Py.jpg
[Updated on: Wed, 16 January 2013 07:44 UTC]
Re: High output STL detail [message #62065 is a reply to message #60286 ] Thu, 14 February 2013 17:33 UTC Go to previous message
From your photo, it looks like you have a slight curve to the surface of your model and that is resulting in stepping. To prevent the stepping, either remove the curve and make it flat, or make the curve more pronounced. increasing the triangle count won't help.
Previous Topic:Rubber
Next Topic:the finish in black strong & flexible is similar to the other colors?
