Home » Support » 3D Design » How to turn a finely tesselated flat area into a couple of faces
How to turn a finely tesselated flat area into a couple of faces [message #59832] Tue, 08 January 2013 14:22 UTC Go to next message
avatar bib993  is currently offline bib993
Hi Shapers!
This is a screenshot of a simplified fractal model I'm working on.
http://fc01.deviantart.net/fs71/f/2013/008/a/8/capture_by_bib993-d5qu5s0.jpg
For information, I get this mesh by applying marching cubes on a set of voxel slices (in a program called Fiji). As you notice, due to the marching cubes process, it generates a detailed grid and this consumes a lot of faces, so I'm hitting the 1 million limit (actually I have more than 5 millions faces in my mesh).
I am confident that this can be reduced a lot by simplyfing all these large flat beams into a couple of faces, because the small faces are well aligned (or at least they look so).
I have tried various options in Meshlab. So far I got the best results using the Quadric Edge Collapse Decimation, but due to the strong decimation factor, I get some inconsistencies and a mesh full of problems that Netfabb cannot fix automatically, and also it affects edges and detailed areas that I'd like to keep intact.
http://fc06.deviantart.net/fs70/f/2013/008/1/8/capture2_by_bib993-d5qu6hf.jpg
I also thought that the tri-to-quad filters could help to merge 2 adjacent triangles into a square, thus reducing by about 50% de number of faces, but it seems that doesn't work this way.
And I also can't prepare the mesh with some smoothing before decimation because that would soften the right angles all over the place.
Any advice on the best decimation strategy in this case? Testing all the options combinations in the Quadric Edge Collapse Decimation dialog takes a lot of time and trial and error, so I wonder if anyone has gone through this already? In particular, I am not sure if I should use the "Planar simplication" option or not.
Regards
bib
[Updated on: Tue, 08 January 2013 14:48 UTC]
Jérémie
Re: How to turn a finely tesselated flat area into a couple of faces [message #59845 is a reply to message #59832 ] Tue, 08 January 2013 17:48 UTC Go to previous messageGo to next message
Replying to myself Smile
The key feature to do this is called "Merge co-planar faces". I will do more research but it looks quite promising with tools like Polygon Cruncher, and maybe Sketchup...
Jérémie
Re: How to turn a finely tesselated flat area into a couple of faces [message #59858 is a reply to message #59845 ] Tue, 08 January 2013 21:47 UTC Go to previous messageGo to next message
I tried different software packages that offer the "Merge coplanar faces" feature but they're really slow or crashing even by just importing the mesh which has got 5.5M faces (248 MB STL file).
I thought Meshlab, which has got a wealth of specialized filters, would offer such a simple feature! That's sad because Meshlab is so efficient at handling large meshes.
Does anyone know a free program that can merge coplanar faces on large meshes? (Sketchup can do the job at DAE import time, but is too slow with large meshes).
Jérémie
Re: How to turn a finely tesselated flat area into a couple of faces [message #59867 is a reply to message #59858 ] Tue, 08 January 2013 22:20 UTC Go to previous messageGo to next message
Have you tried Blender?
http://wiki.blender.org/index.php/Doc:2.6/Manual/Modifiers/G enerate/Decimate
jacantdesign@gmail.com
Re: How to turn a finely tesselated flat area into a couple of faces [message #59869 is a reply to message #59867 ] Tue, 08 January 2013 22:39 UTC Go to previous message
Thanks for the link. It seems quite similar to quadric edge collapse decimation in Meshlab. What I'm specifically looking for is to simplify only 100% (or 99.9%) planar areas.
[Updated on: Tue, 08 January 2013 22:41 UTC]
Jérémie
Previous Topic:Help needed: How to apply inward curved surface to line model?
Next Topic:Need help on curving with Blender
