| First time uploader [message #59523] Thu, 03 January 2013 00:58 UTC |
Hello Shapeways forum,
I've modelled a simplified elephant head in Blender which I need help/advice on how to get it accepted, this is the first time I've used Shapeways. I've rotated it, and uploaded it every way I could think of, but cannot seem to get it accepted. Each time I upload, I get the 'Your model was too big for any of our 3D Printers.' The model is 53.983cm x 55.109cm x 33.576cm, which fits within the maximum bounds for the 650 x 350 x 550 mm (White Strong & Flexible material).
I emailed support, and they said although the file is within the bounds, it is showing little to no volume, this is why the system is rejecting it. They suggested I post it on the forums.
I've attached the model - could someone tell me what I need to do to fix my model? Also, which is the correct way to rotate the model for printing, eg. the trunk pointing up/forward/left/right? Note: the walls are all 1mm thick- i used the 'Solididy' modifier to create the walls when I finished modelling the object.
Trent
| Re: First time uploader [message #59524 is a reply to message #59523 ] Thu, 03 January 2013 01:34 UTC |
The walls are not 1mm thick.. in may places you've got "back" walls that are completely missing.
Download a copy of Netfabb Basic and use it to look at your model.
All these red surfaces are improper. I don't know Blender, but you need to re-work the model.
You are aware that at that size, the model is going to cost more than $1000, right?
http://stonysmith.com/wired/VolumeEstimator.asp?L=530&W= 551&H=335&T=1
Attachment: elephant.jpg
(Size: 125.53KB, Downloaded 166 time(s))
| Re: First time uploader [message #59525 is a reply to message #59523 ] Thu, 03 January 2013 01:56 UTC |
Your model has no thickness, it is just a skin. You need to add a modifier - solidify.
I don't know what the part at the bottom is supposed to be, it looks like wire mesh as in 'wire mesh' you will have to fix this as well.
Attachment: elephant.png
(Size: 23.50KB, Downloaded 160 time(s))
jacantdesign@gmail.com
| Re: First time uploader [message #59527 is a reply to message #59525 ] Thu, 03 January 2013 02:57 UTC |
Thanks so much for your replies. I'm downloading the netfab tool now. I did apply the 1mm solidify to the whole object, but I guess that didn't work as expected. Also the bottom/back piece was just a wall mount and holes for electronics (it's supposed to be a lamp shade kind of thing, that's why i need it hollow).
I had no idea it would cost that much money! Wow. I thought it would be cheap because there are not many polygons, and it's hollow on the inside? Is there anything I can do (without shrinking the size too much) to bring the costs down? Eg. print it as a wireframe only.
| Re: First time uploader [message #59534 is a reply to message #59523 ] Thu, 03 January 2013 06:22 UTC |
It is just not manifold. You want your model to have a connected outer surface to begin with, Once that is accomplished,you can remove a face from the surface, and then apply a solidify mod.
Stoney the red faces were caused by the solidify being applied, creating faces so close that they turned into face on face intersection, thus what appeared as 1 face were actually 2 faces, with normals pointing in both directions. In other words it had uber doubles, thus the red faces in NF. The model was unique you have to admit. The odd grid I have no idea
| Re: First time uploader [message #59535 is a reply to message #59523 ] Thu, 03 January 2013 06:41 UTC |
Trent, creating a model for 3D printing is just totally different from creating one for a good render. Do what I did, SW has some really good tutorials to help explain the basics. After reading them a couple of times, and reading forum posts, I had an "Eureka" moment. I am still pretty dumb, but I sorta understood the principles better than I did. And Blender has some really good tools for creating a model for a 3D print, so you are ahead of most.
You need any help, you are free to pm me.
| Re: First time uploader [message #59542 is a reply to message #59535 ] Thu, 03 January 2013 10:33 UTC |
Thanks Keith, I guess I still have a lot to learn with 3D printing. BTW, really impressed with the SW community on these forums.
| Re: First time uploader [message #59547 is a reply to message #59527 ] Thu, 03 January 2013 12:23 UTC |
| trentbrooks wrote on Thu, 03 January 2013 02:57 |
Number of polygons in itself does not influence the cost of the part - you pay for the volume of material actually used in printing, and a big sheet 1mm thick will simply be expensive no matter how much you crumple it. (Although there is a discontiuity in the price model at some point - beyond a certain model size, a 50% discount is applied provided that the average density of the model stays above another threshold. )
Reducing the head to a wireframe should help - but be sure to read the "stag head" saga that was on the shapeways blog a few weeks ago for added perspective.
