Home » Community » 3D modeler needed » Need ZBrush and Rhyno specialist
Need ZBrush and Rhyno specialist [message #59283] Fri, 28 December 2012 01:18 UTC Go to next message
avatar naga_prime  is currently offline naga_prime
Hi Shapeways community:)
I need help correcting a shape (in STL format) for an urgent project.
Corrections 1) to make one side of the shape symmetric to the other 2) to make the base of the model flat (now it is bumpy and wobbles when put on a table. And after the 2 corrections we need to make sure that the model is printable:)
Also, there are more project in creating from scratch....
PLease send your example of work and brief description,
Ana
Re: Need ZBrush and Rhyno specialist [message #59290 is a reply to message #59283 ] Fri, 28 December 2012 08:44 UTC Go to previous messageGo to next message
avatar gafsadesign is currently online gafsadesign
heloo you can visit my shop to see my work
contact me
wassymj89@gmail.com
Re: Need ZBrush and Rhyno specialist [message #59334 is a reply to message #59283 ] Sat, 29 December 2012 03:01 UTC Go to previous messageGo to next message
avatar codexehow  is currently offline codexehow
Send me what you have so far and I'll let you know if I can help you. You can find contact info at the site listed in my sig.
www.tommycharlesportfolio.com
Re: Need ZBrush and Rhyno specialist [message #59708 is a reply to message #59283 ] Sun, 06 January 2013 08:13 UTC Go to previous message
Symmetry and flat on the bottom will take only a few seconds to fix. Check out my shop if you wanna see some of my work. The only programs I use are zbrush 4r4 and Rhino 3d.
You can always import the .stl file into zbrush and do an X axys symmetry weld. It only takes a second.
Geometry>Modify Topology>Mirror and Weld
To make the bottom flat, all you need to do is in zbrush, go to the Deformation menu and select Flatten at the Y axis to flatten from the bottom up.
- Sal G -
My Website
www.sgcustomsilver.com
Facebook Page
Previous Topic:3D model wanted
Next Topic:I need a modeler to help me complete a 3d project
