Home » Community » General Discussion » Lotion bottle?
Lotion bottle? [message #58562] Thu, 13 December 2012 16:33 UTC Go to next message
avatar dilettante  is currently offline dilettante
I'd love to be able to print a bottle to hold lotions.
Is it possible to print a bottle out of SFP and coat it to make it watertight and "reasonable" foodsafe?
Or using either Fine Detail Plastic and Frosted Detail Plastic?
Re: Lotion bottle? [message #58564 is a reply to message #58562 ] Thu, 13 December 2012 16:58 UTC Go to previous messageGo to next message
Check the thread here:
http://www.shapeways.com/forum/index.php?t=msg&th=11960& amp;start=0&
Re: Lotion bottle? [message #58567 is a reply to message #58564 ] Thu, 13 December 2012 17:23 UTC Go to previous messageGo to next message
What stonysmith just wrote. Also, the nylon material will probably be stiffer than the typical
blow-molded polyethylene bottles (assuming you want the squeeze-bottle type) and the
detail materials too brittle. If you aim for the dispenser-type instead, ceramics would be a
natural choice (with the plastic pump mechanism bought elsewhere or cannibalized from
some other lotion bottle)
Re: Lotion bottle? [message #58583 is a reply to message #58567 ] Thu, 13 December 2012 22:07 UTC Go to previous message
Thanks for the replies.
From what I read, Strong and Flexible, although not as flexible as normal bottles, should still be flexible enough, and would probably not be a problem to hold lotions (no alcohol, no risk of microbial growth, no need for cleaning).
So the last remaining question would be... is there a way to make it watertight, some kind of sealant maybe?
Previous Topic:3d printing how to explain it?
Next Topic:Creating a Print - Someone's already done it!
