Home » Support » 3D Design » Intersection of materials accepted?
Intersection of materials accepted? [message #58150] Fri, 07 December 2012 09:04 UTC Go to next message
avatar keesvos  is currently offline keesvos
Hello all,
I'm working on a scaled model of a car we build. The drawing is made in Solidworks, all parts fitted together in a assembly.
As I have the drawing now, the chassis beams run through the body material
Attached a screenshot of the front wheel with the chassis and the body. As you can see the tube runs trough the body. On this intersection there is 2x material. (what in real life wouldn't be possible)
My question, is it possible to upload this file and would it be printed normally?
Re: Intersection of materials accepted? [message #58153 is a reply to message #58150 ] Fri, 07 December 2012 09:21 UTC Go to previous messageGo to next message
Yes, our Mesh Medic software will merge those volumes into one for you:
http://www.shapeways.com/blog/archives/398-mesh-medic-automa tic-3d-printing-file-repair.html
Re: Intersection of materials accepted? [message #58154 is a reply to message #58150 ] Fri, 07 December 2012 09:25 UTC Go to previous messageGo to next message
Shapeways Mesh Medic software will boolean all of the intersecting parts into one mesh on upload, so there's no double volume to worry about. If your model has some very small meshes it is possible that Mesh Medic will see those meshes as 'ghost' meshes and remove them (more info). An alternative is to use Net Fabb Cloud Service for boolean joining and error checking before uploading to Shapeways.
icon14.gif  Re: Intersection of materials accepted? [message #58157 is a reply to message #58154 ] Fri, 07 December 2012 09:34 UTC Go to previous message
Great! Then I'll finalize my model en run it through the software and upload it. Thanks for the fast help!
Previous Topic:"We don't cast pins"?
Next Topic:text is not placed/rotated correctly
