| Cufflink dimensions [message #58015] Wed, 05 December 2012 14:14 UTC |
Hi there, I'm currently working on a cufflink for a client. I'm new to cufflink field, so I would appreciate if any one can share some information:
I need to know the distance between the two ends as shown below, preferably in mm.
again, thanks in advance to anyone who share this dimension.
[Updated on: Wed, 05 December 2012 14:16 UTC] Plain Orb
| Re: Cufflink dimensions [message #58139 is a reply to message #58015 ] Fri, 07 December 2012 01:18 UTC |
I found many cufflinks in the market with stem length from 12mm to 20mm. Do they just fit different cuff sizes ?
Plain Orb
| Re: Cufflink dimensions [message #58165 is a reply to message #58015 ] Fri, 07 December 2012 13:58 UTC |
I moved you to general, as I think you might find more help here.
| Re: Cufflink dimensions [message #58172 is a reply to message #58169 ] Fri, 07 December 2012 15:55 UTC |
I designed mine with a length of about 13mm, but that includes a slight bend so the design will stay upright..
Hope this helps!
www.RayTomlinDesigns.com
| Re: Cufflink dimensions [message #58240 is a reply to message #58172 ] Sat, 08 December 2012 13:51 UTC |
Thanks! and your stem looks cool ~
Plain Orb
| Re: Cufflink dimensions [message #58324 is a reply to message #58245 ] Mon, 10 December 2012 12:20 UTC |
I design in Solidworks. I found multi-substance design will make the design process of cufflinks much more efficient. It allows you to play tricks on each part of the cufflink and combine them together at last when you think it's perfect.
Plain Orb
| Re: Cufflink dimensions [message #58329 is a reply to message #58324 ] Mon, 10 December 2012 15:14 UTC |
I use Blender 3d for all of my modeling.
What is " multi-substance design"? It may be called something else in Blender.. But I'm not familiar with it.
Ray
| Re: Cufflink dimensions [message #58389 is a reply to message #58329 ] Tue, 11 December 2012 11:35 UTC |
It means editing each part of the model independently and export the whole model as one part. That will bring you more flexibility during designing.
Plain Orb
