| Triple gear [message #57944] Tue, 04 December 2012 07:03 UTC |
In this unusual mechanism three gears mesh together in pairs, and yet they can turn!
If you take three ordinary gears and put them together so that each gear meshes with the other two, then none of the gears can turn because neighbouring gears must turn in opposite directions. Triple gear avoids this problem by having the three "gears" arranged like linked rings - the gears then rotate along skew axes, and the opposite direction rule no longer applies (although see also Oskar van Deventer's Magic Gears for another possible solution).
This is joint work with Saul Schleimer. We were inspired by another of Oskar's designs, his Knotted Gear, which consists of two linked rings that gear with each other, and of course we wondered if it would be possible to do three linked rings!
Youtube video.
Shapeways shop.
| Re: Triple gear [message #58934 is a reply to message #58925 ] Thu, 20 December 2012 09:25 UTC |
Yes, this is a truly amazing design.
| Re: Triple gear [message #69165 is a reply to message #67948 ] Tue, 04 June 2013 13:10 UTC |
Another animated gif, this time of the powered version:
Also, here is a video showing how to loosen the gears if they arrive somewhat fused together.
