| Ceramics Details (Need help!) [message #57612] Wed, 28 November 2012 15:21 UTC |
Hi, I'm working on this project (see attachment. How much will be lost for the glazing? I know it won't be that detailed as in this render, but will it be somewhat visible? Is there a way to know how it will look before I send it in (like a trick in a 3D program, something like offset 1 mm glaze)? And do you think the structure will hold it? Should I make the top part thicker?
Attachment: Concept.jpg
(Size: 393.22KB, Downloaded 166 time(s))
[Updated on: Wed, 28 November 2012 15:23 UTC]
| Re: Ceramics Details (Need help!) [message #57617 is a reply to message #57612 ] Wed, 28 November 2012 16:47 UTC |
The glaze is around 1mm thick. So smaller holes will close (will even cost you less to close them as that will lower the surface area). The details that will be lost are the sharped edged details. So you'll still have the larger holes, but the tentacle suction cups looking parts will be smoother and less sharp.
[Updated on: Wed, 28 November 2012 18:34 UTC] The Mad Moder
| Re: Ceramics Details (Need help!) [message #57623 is a reply to message #57617 ] Wed, 28 November 2012 17:24 UTC |
If you follow the workflow here:
https://sites.google.com/site/3dprintfaq/workflows/hollowing -a-model
That process at one point generates both an internal (smaller) and external (larger) shell. around your object.
This process normally has you remove the (outer) shell, but that larger shell (if you set it up for 1mm) is the one you are looking for.
In other programs other than Meshlab, it's called Minkowski sum. <grin>
