Painting colorless sandstone model
Painting colorless sandstone model [message #57277] Thu, 22 November 2012 14:26 UTC Go to next message
avatar montyman77  is currently offline montyman77
Does anyone know if it is possible to paint a sandstone model? If so what kind of paint would I get?
Re: Painting colorless sandstone model [message #57391 is a reply to message #57277 ] Sat, 24 November 2012 21:12 UTC Go to previous messageGo to next message
Most types of hobby or artists paints should work (e.g.acrylics or enamels)
Main problem will be that the material is rather porous, so it soaks up paint, unless you prime it really well.
Greetings
Dragoman
Re: Painting colorless sandstone model [message #84928 is a reply to message #57391 ] Sat, 15 February 2014 08:33 UTC Go to previous messageGo to next message
avatar LucaMC  is currently offline LucaMC
Dragoman wrote on Sat, 24 November 2012 21:12
Greetings
Dragoman
Hi. If I have an item printed in multicolor sandstone and I wanted to give a clear varnish to make it shiny, I should use a transparent primer, but I would not risk ruining the object's colors?
Thank you.
Re: Painting colorless sandstone model [message #84931 is a reply to message #84928 ] Sat, 15 February 2014 10:21 UTC Go to previous messageGo to next message
avatar HOLDEN8702  is currently offline HOLDEN8702
Hi.
I'm anxious waiting my first robots in full color sandstone to try clear varnish and diferent coats and shades. (next week, yeah!)
This man have made it and the results is very promising
https://www.shapeways.com/model/880395/portal-pressure-butto n-coaster.html?li=feed&materialId=26
and somebody writes long time ago this interesting post
https://www.shapeways.com/forum/index.php?t=msg&goto=392 21&srch=sandstone+color+test#msg_39221
I hope this help you. But best is to do a coat test in the base or in a hidden place. Some varnish could mix with the original ink.
regards
Luis
Re: Painting colorless sandstone model [message #89924 is a reply to message #84931 ] Mon, 19 May 2014 01:34 UTC Go to previous message
avatar designanything3d  is currently offline designanything3d
I've had good results. See http://www.shapeways.com/forum/index.php?t=msg&th=14158& amp;start=0& at the bottom. The balloon figurine was sandstone. Sprayed with primer filler, 1200 grit sand paperand 2 coats of gloss red. Was a near mirror reflection.
Previous Topic:cutting apart print for mold making
Next Topic:How to give Elasto Plastic a silver metallic surface
