moving parts
Discussion in 'Materials' started by Brick, Nov 13, 2012.
  1. Brick
    Brick Member
    anything I need to know when creating models with moving parts?
  2. virtox
    virtox Active Member Moderator
    The minimal clearance for WSF is 0.5 mm.
    But it is usually wise to avoid large surface with near contact for with moving parts.
    As this increases the chances of powder jamming up or causing to much friction.
    Stijn
  3. Brick
    Brick Member
    ok ty.
    You only mention WSF....is that the only material where you can do moving parts?
  4. stonysmith
    By no means is WSF the only material which you can do moving parts. Sandstone, and all the "Detail" materials (and some others) can have moving parts as well.
    On each of the materials pages, you can see what the minimum clearance is and/or whether that material support "interlocking" parts.
