| Marketing piece need advice... [message #56567] Fri, 09 November 2012 18:15 UTC |
I figure this will be 7"x5"x10" tall. The smallest bar (horizontal ties) are right at that magical .7cm mark.
How thick should that base material be? Do you think it would require a strap going front to back across the bottom to keep it from spreading/flexing and breaking? This will be a desktop piece but somone would still be lifting the H out of it and putting it back. I have little cups under the H supported from the top.
I was thinking strong flexible material. Anyhow I've never done 3d printing before and would like some feedback.
Attachment: Xv2.JPG
(Size: 36.24KB, Downloaded 69 time(s))
[Updated on: Fri, 09 November 2012 18:16 UTC]
| Re: Marketing piece need advice... [message #56582 is a reply to message #56567 ] Sat, 10 November 2012 00:10 UTC |
Which "magical .7cm mark" are you talking about?
[Updated on: Sat, 10 November 2012 00:11 UTC]
| Re: Marketing piece need advice... [message #56686 is a reply to message #56582 ] Mon, 12 November 2012 14:07 UTC |
I assume he means the .7mm (not cm) minimum wall thickness for Strong & Flexible Plastic?
| Re: Marketing piece need advice... [message #56820 is a reply to message #56567 ] Wed, 14 November 2012 10:09 UTC |
Hey Wise
Nice design.
I agree WSF would be the best choice (for price and durability). As for the base, i have had a sheet printed at 3mm thickness and it was rigid with only a small amount of flex when force-ably bent (by hand). All my other prints 2mm and below are very flexible.
This may increase the price quite dramatically so you could create more cutouts in the base, without effecting the overall stability. The material is porous and so surprisingly light.
If your dont wish to make the base that thick then ribbing on the inside face is also an option.
Note: the larger the thickness, the larger a hole needs to be be, i mention this because your text looks thin in areas.
For a more detailed design rules, please refer to:
http://www.shapeways.com/tutorials/design_rules_for_3d_print ing
BTW i try to stick to 1mm as my thinnest wall size in all directions, this is a general rule for most 3d printing processes
formerly known as pdb
