Home » Community » General Discussion » Wall Thickness Help Using Blender
Wall Thickness Help Using Blender [message #56256] Sat, 03 November 2012 13:28 UTC Go to next message
avatar Swavek  is currently offline Swavek
After months of working in Blender I'm finally getting the modeling and scaling down, but not so with wall thickness. The solidify modifier is a convenient automatic tool to make wall thickness. But I'm not sure if it actually represents the same number that is optimal for 3D printing minimum thickness of ".07mm", ie. If I type in ".07" in the setting, does that really correspond with .07 mm thickness if I upload stating I'm using mm units? Any light on this is appreciated. Thanks.
Re: Wall Thickness Help Using Blender [message #56257 is a reply to message #56256 ] Sat, 03 November 2012 13:34 UTC Go to previous messageGo to next message
To make sure, do you mean 0.7 mm?
Re: Wall Thickness Help Using Blender [message #56258 is a reply to message #56257 ] Sat, 03 November 2012 13:59 UTC Go to previous messageGo to next message
When I work in Blender I find that using cm is easier than mm. For example I'm making a cylinder shaped container that is going to be 28 cm high and 10 cm in diameter (real world). The model on my screen I'm using 28 blender units by 10 blender units width. So actually, I would think of applying .07 (of the units). After I'm done I select the whole thing and scale it by 10 to make into mm in order to upload which will be .7mm?.
Re: Wall Thickness Help Using Blender [message #56259 is a reply to message #56258 ] Sat, 03 November 2012 14:28 UTC Go to previous messageGo to next message
avatar victorrings  is currently offline victorrings
why are you not using the METRIC in the units section? this would clear up any confusion.
my website is online at
http://victorrings.weebly.com/
RINGS GALORE!
Re: Wall Thickness Help Using Blender [message #56321 is a reply to message #56259 ] Mon, 05 November 2012 15:59 UTC Go to previous message
When you are in Blender, To the right in the Properties panel, click the second button for Scene. The Third section down will be the section for Units. If you select Metric, You will be assured to get the exact size you are looking for. Just make sure you are working in Millimeters and not Centimeters or Meters.
I hope this Helps!
Ray
www.RayTomlinDesigns.com
Previous Topic:Choices of Material for Chopsticks
Next Topic:Back to sender...
