Is it just me or did something change in the way .wrl files for color prints are checked?
I did quite some
color prints in the past and thought I had my workflow down.
However I had quite some difficulty when I tried to upload a color model the last few attempts. The error emails do not specify what the problem is however only that I need to give my model a bit of extra love.
I took the existing grandpa model and made a 'sinterklaas' version of it (hope the family will be amused next december
I kept the triangles well under 500.000 did all kinds of error checks... Also I opened the wrl in notepad to make sure the texture name and path check out.
Below are 2 exports of exactly the same source. One is a .STL without color. The other is a .WRL with texture.
imageafter.com/temp/tristan/SinterOpa3STL.zip
imageafter.com/temp/tristan/SinterOpa3WRLcolor.zip
The STL uploads perfectly however the .WRL 'needs more love'
Anyone an idea what is wrong?
Does the server check wall thickness when uploading an .WRL? If so that could be the problem since the wall thickness of colored sandstone is 3mm and the white strong and flexible is 0.7 but I guess if that is checked it would be easy to mention in the error email right?
